[petsc-users] Strange efficiency in PETSc-dev using OpenMP
Danyang Su danyang.su at gmail.com
Mon Sep 23 15:40:29 CDT 2013
On 23/09/2013 12:33 PM, Jed Brown wrote:
> Barry Smith <bsmith at mcs.anl.gov> writes:
>>     So when you compile the software to use OpenMP it is slow;
>>     regardless of whether you use OpenMP explicitly or not. When you
>>     compile the software to NOT use OpenMP then it is much faster?
> Are you running multiple MPI processes?  How are the affinities set?
> Are any other jobs competing for the same pinned core as your
> application?
No. Only one MPI processes is running. And no other application is
competing for the cores. The affinities and threads mapping are as
follows. All the threads are assigned to a distinct core.
KMP_AFFINITY=verbose,granularity=fine,compact
OMP: Info #204: KMP_AFFINITY: decoding x2APIC ids.
OMP: Info #202: KMP_AFFINITY: Affinity capable, using global cpuid leaf
11 info
OMP: Info #154: KMP_AFFINITY: Initial OS proc set respected:
{0,1,2,3,4,5,6,7,8,9,10,11}
OMP: Info #156: KMP_AFFINITY: 12 available OS procs
OMP: Info #157: KMP_AFFINITY: Uniform topology
OMP: Info #179: KMP_AFFINITY: 1 packages x 6 cores/pkg x 2 threads/core
(6 total cores)
OMP: Info #206: KMP_AFFINITY: OS proc to physical thread map:
OMP: Info #171: KMP_AFFINITY: OS proc 0 maps to package 0 core 0 thread 0
OMP: Info #171: KMP_AFFINITY: OS proc 1 maps to package 0 core 0 thread 1
OMP: Info #171: KMP_AFFINITY: OS proc 2 maps to package 0 core 1 thread 0
OMP: Info #171: KMP_AFFINITY: OS proc 3 maps to package 0 core 1 thread 1
OMP: Info #171: KMP_AFFINITY: OS proc 4 maps to package 0 core 2 thread 0
OMP: Info #171: KMP_AFFINITY: OS proc 5 maps to package 0 core 2 thread 1
OMP: Info #171: KMP_AFFINITY: OS proc 6 maps to package 0 core 3 thread 0
OMP: Info #171: KMP_AFFINITY: OS proc 7 maps to package 0 core 3 thread 1
OMP: Info #171: KMP_AFFINITY: OS proc 8 maps to package 0 core 4 thread 0
OMP: Info #171: KMP_AFFINITY: OS proc 9 maps to package 0 core 4 thread 1
OMP: Info #171: KMP_AFFINITY: OS proc 10 maps to package 0 core 5 thread 0
OMP: Info #171: KMP_AFFINITY: OS proc 11 maps to package 0 core 5 thread 1
OMP: Info #144: KMP_AFFINITY: Threads may migrate across 1 innermost
levels of machine
OMP: Info #147: KMP_AFFINITY: Internal thread 0 bound to OS proc set {0}
OMP: Info #147: KMP_AFFINITY: Internal thread 1 bound to OS proc set {1}
OMP: Info #147: KMP_AFFINITY: Internal thread 2 bound to OS proc set {2}
OMP: Info #147: KMP_AFFINITY: Internal thread 3 bound to OS proc set {3}
