[petsc-users] Strange efficiency in PETSc-dev using OpenMP
Danyang Su danyang.su at gmail.com
Mon Sep 23 14:13:48 CDT 2013
Hi Barry,
Another strange problem:
Currently I have PETSc-3.4.2 MPI version and PETSc-dev OpenMP version on
my computer, with different environment variable of PETSC_ARCH and
PETSC_DIR. Before installation of PETSc-dev OpenMP version, the
PETSc-3.4.2 MPI version works fine. But after installation of PETSc-dev
OpenMP version, the same problem exist in PETSc-3.4.2 MPI version if run
with 1 processor, but no problem with 2 or more processors.
Danyang
On 23/09/2013 12:01 PM, Danyang Su wrote:
> Hi Barry,
> Sorry I forgot the message in the previous email. It is still slow
> when run without the "-threadcomm_type openmp -threadcomm_nthreads 1"
> Thanks,
> Danyang
> On 23/09/2013 11:43 AM, Barry Smith wrote:
>>     You did not answer my question from yesterday:
>>   If you run the Openmp compiled version WITHOUT the
>>   command line options is it still slow?
>> On Sep 23, 2013, at 1:33 PM, Danyang Su <danyang.su at gmail.com> wrote:
>>> Hi Shri,
>>> It seems that the problem does not result from the affinities
>>> setting for threads. I have tried several settings, the threads are
>>> set to different cores, but there is no improvement.
>>> Here is the information of package, core and thread maps
>>> OMP: Info #204: KMP_AFFINITY: decoding x2APIC ids.
>>> OMP: Info #202: KMP_AFFINITY: Affinity capable, using global cpuid
>>> leaf 11 info
>>> OMP: Info #154: KMP_AFFINITY: Initial OS proc set respected:
>>> {0,1,2,3,4,5,6,7,8,9,10,11}
>>> OMP: Info #156: KMP_AFFINITY: 12 available OS procs
>>> OMP: Info #157: KMP_AFFINITY: Uniform topology
>>> OMP: Info #179: KMP_AFFINITY: 1 packages x 6 cores/pkg x 2
>>> threads/core (6 total cores)
>>> OMP: Info #206: KMP_AFFINITY: OS proc to physical thread map:
>>> OMP: Info #171: KMP_AFFINITY: OS proc 0 maps to package 0 core 0
>>> thread 0
>>> OMP: Info #171: KMP_AFFINITY: OS proc 1 maps to package 0 core 0
>>> thread 1
>>> OMP: Info #171: KMP_AFFINITY: OS proc 2 maps to package 0 core 1
>>> thread 0
>>> OMP: Info #171: KMP_AFFINITY: OS proc 3 maps to package 0 core 1
>>> thread 1
>>> OMP: Info #171: KMP_AFFINITY: OS proc 4 maps to package 0 core 2
>>> thread 0
>>> OMP: Info #171: KMP_AFFINITY: OS proc 5 maps to package 0 core 2
>>> thread 1
>>> OMP: Info #171: KMP_AFFINITY: OS proc 6 maps to package 0 core 3
>>> thread 0
>>> OMP: Info #171: KMP_AFFINITY: OS proc 7 maps to package 0 core 3
>>> thread 1
>>> OMP: Info #171: KMP_AFFINITY: OS proc 8 maps to package 0 core 4
>>> thread 0
>>> OMP: Info #171: KMP_AFFINITY: OS proc 9 maps to package 0 core 4
>>> thread 1
>>> OMP: Info #171: KMP_AFFINITY: OS proc 10 maps to package 0 core 5
>>> thread 0
>>> OMP: Info #171: KMP_AFFINITY: OS proc 11 maps to package 0 core 5
>>> thread 1
>>> OMP: Info #144: KMP_AFFINITY: Threads may migrate across 1 innermost
>>> levels of machine
>>> And here is the internal thread bounding with different kmp_affinity
>>> settings:
>>> 1. KMP_AFFINITY=verbose,granularity=thread,compact
>>> OMP: Info #147: KMP_AFFINITY: Internal thread 0 bound to OS proc set
>>> {0}
>>> OMP: Info #147: KMP_AFFINITY: Internal thread 1 bound to OS proc set
>>> {1}
>>> OMP: Info #147: KMP_AFFINITY: Internal thread 2 bound to OS proc set
>>> {2}
>>> OMP: Info #147: KMP_AFFINITY: Internal thread 3 bound to OS proc set
>>> {3}
>>> 2. KMP_AFFINITY=verbose,granularity=fine,compact
>>> {0}
>>> {1}
>>> {2}
>>> {3}
>>> 3. KMP_AFFINITY=verbose,granularity=fine,compact,1,0
>>> {0}
>>> {2}
>>> {4}
>>> {6}
>>> 4. KMP_AFFINITY=verbose,scatter
>>> {0,1}
>>> {2,3}
>>> {4,5}
>>> {6,7}
>>> 5. KMP_AFFINITY=verbose,compact (For this setting, two threads are
>>> assigned to the same core)
>>> {0,1}
>>> {0,1}
>>> {2,3}
>>> {2,3}
>>> 6. KMP_AFFINITY=verbose,granularity=core,compact  (For this setting,
>>> two threads are assigned to the same core)
>>> {0,1}
>>> {0,1}
>>> {2,3}
>>> {2,3}
>>> The first 4 settings can assign threads to a distinct core, but the
>>> problem is not solved.
>>> Thanks,
>>> Danyang
>>> On 22/09/2013 8:00 PM, Shri wrote:
>>>> I think this is definitely an issue with setting the affinities for
>>>> threads, i.e., the assignment of threads to cores. Ideally each
>>>> thread should be assigned to a distinct core but in your case all
>>>> the 4 threads are getting pinned to the same core resulting in such
>>>> a massive slowdown. Unfortunately, the thread affinities for OpenMP
>>>> are set through environment variables. For Intel's OpenMP one needs
>>>> to define the thread affinities through the environment variable
>>>> KMP_AFFINITY. See this document here
>>>> http://software.intel.com/sites/products/documentation/studio/composer/en-us/2011Update/compiler_c/optaps/common/optaps_openmp_thread_affinity.htm.
>>>> Try setting the affinities via KMP_AFFINITY and let us know if it
>>>> works.
>>>> Shri
>>>> On Sep 21, 2013, at 11:06 PM, Danyang Su wrote:
>>>>> Hi Shri,
>>>>> Thanks for your info. It can work with the option -threadcomm_type
>>>>> openmp. But another problem arises, as described as follows.
>>>>> The sparse matrix is  53760*53760 with 1067392 non-zero entries.
>>>>> If the codes is compiled using PETSc-3.4.2, it works fine, the
>>>>> equations can be solved quickly and I can see the speedup. But if
>>>>> the code is compiled using PETSc-dev with OpenMP option, it takes
>>>>> a long time in solving the equations and I cannot see any speedup
>>>>> when more processors are used.
>>>>> For PETSc-3.4.2,  run by "mpiexec -n 4 ksp_inhm_d -log_summary
>>>>> log_mpi4_petsc3.4.2.log", the iteration and runtime are:
>>>>> Iterations     6 time_assembly  0.4137E-01 time_ksp 0.9296E-01
>>>>> For PETSc-dev,  run by "mpiexec -n 1 ksp_inhm_d -threadcomm_type
>>>>> openmp -threadcomm_nthreads 4 -log_summary
>>>>> log_openmp_petsc_dev.log", the iteration and runtime are:
>>>>> Iterations     6 time_assembly  0.3595E+03 time_ksp 0.2907E+00
>>>>> Most of the time 'time_assembly  0.3595E+03' is spent on the
>>>>> following codes
>>>>>                  do i = istart, iend - 1
>>>>>                     ii = ia_in(i+1)
>>>>>                     jj = ia_in(i+2)
>>>>>                     call MatSetValues(a, ione, i, jj-ii,
>>>>> ja_in(ii:jj-1)-1, a_in(ii:jj-1), Insert_Values, ierr)
>>>>>                  end do
>>>>> The log files for both PETSc-3.4.2 and PETSc-dev are attached.
>>>>> Is there anything wrong with my codes or with running option? The
>>>>> above codes works fine when using MPICH.
>>>>> Thanks and regards,
>>>>> Danyang
>>>>> On 21/09/2013 2:09 PM, Shri wrote:
>>>>>> There are three thread communicator types in PETSc. The default
>>>>>> is "no thread" which is basically a non-threaded version. The
>>>>>> other two types are "openmp" and "pthread". If you want to use
>>>>>> OpenMP then use the option -threadcomm_type openmp.
>>>>>> Shri
>>>>>> On Sep 21, 2013, at 3:46 PM, Danyang Su <danyang.su at gmail.com>
>>>>>> wrote:
>>>>>>> Hi Barry,
>>>>>>> Thanks for the quick reply.
>>>>>>> After changing
>>>>>>> #if defined(PETSC_HAVE_PTHREADCLASSES) || defined
>>>>>>> (PETSC_HAVE_OPENMP)
>>>>>>> to
>>>>>>> and comment out
>>>>>>> #elif defined(PETSC_HAVE_OPENMP)
>>>>>>> PETSC_EXTERN PetscStack *petscstack;
>>>>>>> It can be compiled and validated with "make test".
>>>>>>> But I still have questions on running the examples. After
>>>>>>> rebuild the codes (e.g., ksp_ex2f.f), I can run it with "mpiexec
>>>>>>> -n 1 ksp_ex2f", or "mpiexec -n 4 ksp_ex2f", or "mpiexec -n 1
>>>>>>> ksp_ex2f -threadcomm_nthreads 1", but if I run it with "mpiexec
>>>>>>> -n 1 ksp_ex2f -threadcomm_nthreads 4", there will be a lot of
>>>>>>> error information (attached).
>>>>>>> The codes is not modified and there is no OpenMP routines in it.
>>>>>>> For the current development in my project, I want to keep the
>>>>>>> OpenMP codes in calculating matrix values, but want to solve it
>>>>>>> with PETSc (OpenMP). Is it possible?
>>>>>>> Thanks and regards,
>>>>>>> Danyang
>>>>>>> On 21/09/2013 7:26 AM, Barry Smith wrote:
>>>>>>>>    Danyang,
>>>>>>>>       I don't think the  || defined (PETSC_HAVE_OPENMP)
>>>>>>>> belongs in the code below.
>>>>>>>> /*  Linux functions CPU_SET and others don't work if sched.h is
>>>>>>>> not included before
>>>>>>>>      including pthread.h. Also, these functions are active only
>>>>>>>> if either _GNU_SOURCE
>>>>>>>>      or __USE_GNU is not set (see /usr/include/sched.h and
>>>>>>>> /usr/include/features.h), hence
>>>>>>>>      set these first.
>>>>>>>> (PETSC_HAVE_OPENMP)
>>>>>>>> Edit include/petscerror.h and locate these lines and remove
>>>>>>>> that part and then rerun make all.  Let us know if it works or
>>>>>>>> not.
>>>>>>>>     Barry
>>>>>>>> i.e. replace
>>>>>>>> (PETSC_HAVE_OPENMP)
>>>>>>>> with
>>>>>>>> On Sep 21, 2013, at 6:53 AM, Matthew Knepley
>>>>>>>> <petsc-maint at mcs.anl.gov>
>>>>>>>>   wrote:
>>>>>>>>> On Sat, Sep 21, 2013 at 12:18 AM, Danyang Su
>>>>>>>>>   wrote:
>>>>>>>>> Hi All,
>>>>>>>>> I got error information in compiling petsc-dev with openmp in
>>>>>>>>> cygwin. Before, I have successfully compiled petsc-3.4.2 and
>>>>>>>>> it works fine.
>>>>>>>>> The log files have been attached.
>>>>>>>>> The OpenMP configure test is wrong. It clearly fails to find
>>>>>>>>> pthread.h, but the test passes. Then in petscerror.h
>>>>>>>>> we guard pthread.h using PETSC_HAVE_OPENMP. Can someone who
>>>>>>>>> knows OpenMP fix this?
>>>>>>>>>      Matt
>>>>>>>>>   Thanks,
>>>>>>>>> Danyang
>>>>>>>>> What most experimenters take for granted before they begin
>>>>>>>>> their experiments is infinitely more interesting than any
>>>>>>>>> results to which their experiments lead.
>>>>>>>>> -- Norbert Wiener
>>>>>>> <error.txt>
>>>>> <log_mpi4_petsc3.4.2.log><log_openmp_petsc_dev.log>
