[petsc-users] How to speed up geometric multigrid
Mark F. Adams mfadams at lbl.gov
Mon Sep 23 13:52:25 CDT 2013
> The simulation does start with both phases and the geometry is supposed to become more complex as the simulation progresses.
> But so far the run is stopped before there are significant changes in the shape of the droplet.
Humm,  not sure why you are seeing degradation then.  I imagine the initial geometry is not grid aligned so I'm not sure why you are seeing degradation in convergence rate.
> I can give a shot to AMG: which options would you suggest to use.
-pc_type gamg -pc_gamg_type agg -pc_gamg_agg_nsmooths 1
> Also, how can I project out the constant from the rhs? Thanks a lot!
http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/KSP/KSPSetNullSpace.html#KSPSetNullSpace
