[petsc-users] Strange efficiency in PETSc-dev using OpenMP
Mon Sep 23 13:43:17 CDT 2013
   You did not answer my question from yesterday:
 If you run the Openmp compiled version WITHOUT the
-threadcomm_nthreads 1
-threadcomm_type openmp
 command line options is it still slow?
On Sep 23, 2013, at 1:33 PM, Danyang Su <danyang.su at gmail.com> wrote:
> Hi Shri,
> It seems that the problem does not result from the affinities setting for threads. I have tried several settings, the threads are set to different cores, but there is no improvement.
> Here is the information of package, core and thread maps
> OMP: Info #204: KMP_AFFINITY: decoding x2APIC ids.
> OMP: Info #202: KMP_AFFINITY: Affinity capable, using global cpuid leaf 11 info
> OMP: Info #154: KMP_AFFINITY: Initial OS proc set respected: {0,1,2,3,4,5,6,7,8,9,10,11}
> OMP: Info #156: KMP_AFFINITY: 12 available OS procs
> OMP: Info #157: KMP_AFFINITY: Uniform topology
> OMP: Info #179: KMP_AFFINITY: 1 packages x 6 cores/pkg x 2 threads/core (6 total cores)
> OMP: Info #206: KMP_AFFINITY: OS proc to physical thread map:
> OMP: Info #171: KMP_AFFINITY: OS proc 0 maps to package 0 core 0 thread 0
> OMP: Info #171: KMP_AFFINITY: OS proc 1 maps to package 0 core 0 thread 1
> OMP: Info #171: KMP_AFFINITY: OS proc 2 maps to package 0 core 1 thread 0
> OMP: Info #171: KMP_AFFINITY: OS proc 3 maps to package 0 core 1 thread 1
> OMP: Info #171: KMP_AFFINITY: OS proc 4 maps to package 0 core 2 thread 0
> OMP: Info #171: KMP_AFFINITY: OS proc 5 maps to package 0 core 2 thread 1
> OMP: Info #171: KMP_AFFINITY: OS proc 6 maps to package 0 core 3 thread 0
> OMP: Info #171: KMP_AFFINITY: OS proc 7 maps to package 0 core 3 thread 1
> OMP: Info #171: KMP_AFFINITY: OS proc 8 maps to package 0 core 4 thread 0
> OMP: Info #171: KMP_AFFINITY: OS proc 9 maps to package 0 core 4 thread 1
> OMP: Info #171: KMP_AFFINITY: OS proc 10 maps to package 0 core 5 thread 0
> OMP: Info #171: KMP_AFFINITY: OS proc 11 maps to package 0 core 5 thread 1
> OMP: Info #144: KMP_AFFINITY: Threads may migrate across 1 innermost levels of machine
> And here is the internal thread bounding with different kmp_affinity settings:
> 1. KMP_AFFINITY=verbose,granularity=thread,compact
> OMP: Info #147: KMP_AFFINITY: Internal thread 0 bound to OS proc set {0}
> OMP: Info #147: KMP_AFFINITY: Internal thread 1 bound to OS proc set {1}
> OMP: Info #147: KMP_AFFINITY: Internal thread 2 bound to OS proc set {2}
> OMP: Info #147: KMP_AFFINITY: Internal thread 3 bound to OS proc set {3}
> 2. KMP_AFFINITY=verbose,granularity=fine,compact
> 3. KMP_AFFINITY=verbose,granularity=fine,compact,1,0
> OMP: Info #147: KMP_AFFINITY: Internal thread 1 bound to OS proc set {2}
> OMP: Info #147: KMP_AFFINITY: Internal thread 2 bound to OS proc set {4}
> OMP: Info #147: KMP_AFFINITY: Internal thread 3 bound to OS proc set {6}
> 4. KMP_AFFINITY=verbose,scatter
> OMP: Info #147: KMP_AFFINITY: Internal thread 0 bound to OS proc set {0,1}
> OMP: Info #147: KMP_AFFINITY: Internal thread 1 bound to OS proc set {2,3}
> OMP: Info #147: KMP_AFFINITY: Internal thread 2 bound to OS proc set {4,5}
> OMP: Info #147: KMP_AFFINITY: Internal thread 3 bound to OS proc set {6,7}
> 5. KMP_AFFINITY=verbose,compact (For this setting, two threads are assigned to the same core)
> OMP: Info #147: KMP_AFFINITY: Internal thread 1 bound to OS proc set {0,1}
> OMP: Info #147: KMP_AFFINITY: Internal thread 2 bound to OS proc set {2,3}
> OMP: Info #147: KMP_AFFINITY: Internal thread 3 bound to OS proc set {2,3}
> 6. KMP_AFFINITY=verbose,granularity=core,compact  (For this setting, two threads are assigned to the same core)
> The first 4 settings can assign threads to a distinct core, but the problem is not solved.
> Thanks,
> Danyang
> On 22/09/2013 8:00 PM, Shri wrote:
>> I think this is definitely an issue with setting the affinities for threads, i.e., the assignment of threads to cores. Ideally each thread should be assigned to a distinct core but in your case all the 4 threads are getting pinned to the same core resulting in such a massive slowdown. Unfortunately, the thread affinities for OpenMP are set through environment variables. For Intel's OpenMP one needs to define the thread affinities through the environment variable KMP_AFFINITY. See this document here http://software.intel.com/sites/products/documentation/studio/composer/en-us/2011Update/compiler_c/optaps/common/optaps_openmp_thread_affinity.htm. Try setting the affinities via KMP_AFFINITY and let us know if it works.
>> Shri
>> On Sep 21, 2013, at 11:06 PM, Danyang Su wrote:
>>> Hi Shri,
>>> Thanks for your info. It can work with the option -threadcomm_type openmp. But another problem arises, as described as follows.
>>> The sparse matrix is  53760*53760 with 1067392 non-zero entries. If the codes is compiled using PETSc-3.4.2, it works fine, the equations can be solved quickly and I can see the speedup. But if the code is compiled using PETSc-dev with OpenMP option, it takes a long time in solving the equations and I cannot see any speedup when more processors are used.
>>> For PETSc-3.4.2,  run by "mpiexec -n 4 ksp_inhm_d -log_summary log_mpi4_petsc3.4.2.log", the iteration and runtime are:
>>> Iterations     6 time_assembly  0.4137E-01 time_ksp  0.9296E-01
>>> For PETSc-dev,  run by "mpiexec -n 1 ksp_inhm_d -threadcomm_type openmp -threadcomm_nthreads 4 -log_summary log_openmp_petsc_dev.log", the iteration and runtime are:
>>> Iterations     6 time_assembly  0.3595E+03 time_ksp  0.2907E+00
>>> Most of the time 'time_assembly  0.3595E+03' is spent on the following codes
>>>                 do i = istart, iend - 1
>>>                    ii = ia_in(i+1)
>>>                    jj = ia_in(i+2)
>>>                    call MatSetValues(a, ione, i, jj-ii, ja_in(ii:jj-1)-1, a_in(ii:jj-1), Insert_Values, ierr)
>>>                 end do
>>> The log files for both PETSc-3.4.2 and PETSc-dev are attached.
>>> Is there anything wrong with my codes or with running option? The above codes works fine when using MPICH.
>>> Thanks and regards,
>>> Danyang
>>> On 21/09/2013 2:09 PM, Shri wrote:
>>>> There are three thread communicator types in PETSc. The default is "no thread" which is basically a non-threaded version. The other two types are "openmp" and "pthread". If you want to use OpenMP then use the option -threadcomm_type openmp.
>>>> Shri
>>>> On Sep 21, 2013, at 3:46 PM, Danyang Su <danyang.su at gmail.com> wrote:
>>>>> Hi Barry,
>>>>> Thanks for the quick reply.
>>>>> After changing
>>>>> #if defined(PETSC_HAVE_PTHREADCLASSES) || defined (PETSC_HAVE_OPENMP)
>>>>> to
>>>>> and comment out
>>>>> #elif defined(PETSC_HAVE_OPENMP)
>>>>> PETSC_EXTERN PetscStack *petscstack;
>>>>> It can be compiled and validated with "make test".
>>>>> But I still have questions on running the examples. After rebuild the codes (e.g., ksp_ex2f.f), I can run it with "mpiexec -n 1 ksp_ex2f", or "mpiexec -n 4 ksp_ex2f", or "mpiexec -n 1 ksp_ex2f -threadcomm_nthreads 1", but if I run it with "mpiexec -n 1 ksp_ex2f -threadcomm_nthreads 4", there will be a lot of error information (attached).
>>>>> The codes is not modified and there is no OpenMP routines in it. For the current development in my project, I want to keep the OpenMP codes in calculating matrix values, but want to solve it with PETSc (OpenMP). Is it possible?
>>>>> Thanks and regards,
>>>>> Danyang
>>>>> On 21/09/2013 7:26 AM, Barry Smith wrote:
>>>>>>   Danyang,
>>>>>>      I don't think the  || defined (PETSC_HAVE_OPENMP)   belongs in the code below.
>>>>>> /*  Linux functions CPU_SET and others don't work if sched.h is not included before
>>>>>>     including pthread.h. Also, these functions are active only if either _GNU_SOURCE
>>>>>>     or __USE_GNU is not set (see /usr/include/sched.h and /usr/include/features.h), hence
>>>>>>     set these first.
>>>>>> Edit include/petscerror.h and locate these lines and remove that part and then rerun make all.  Let us know if it works or not.
>>>>>>    Barry
>>>>>> i.e. replace
>>>>>> with
>>>>>> On Sep 21, 2013, at 6:53 AM, Matthew Knepley
>>>>>> <petsc-maint at mcs.anl.gov>
>>>>>>  wrote:
>>>>>>> On Sat, Sep 21, 2013 at 12:18 AM, Danyang Su <danyang.su at gmail.com>
>>>>>>>  wrote:
>>>>>>> Hi All,
>>>>>>> I got error information in compiling petsc-dev with openmp in cygwin. Before, I have successfully compiled petsc-3.4.2 and it works fine.
>>>>>>> The log files have been attached.
>>>>>>> The OpenMP configure test is wrong. It clearly fails to find pthread.h, but the test passes. Then in petscerror.h
>>>>>>> we guard pthread.h using PETSC_HAVE_OPENMP. Can someone who knows OpenMP fix this?
>>>>>>>     Matt
>>>>>>> Thanks,
>>>>>>> Danyang
>>>>>>> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
>>>>>>> -- Norbert Wiener
>>>>> <error.txt>
>>> <log_mpi4_petsc3.4.2.log><log_openmp_petsc_dev.log>
