[petsc-users] Problem with MatCreateSeqAIJWithArrays
Chung-Kan Huang ckhuangf at gmail.com
Thu Sep 19 00:05:13 CDT 2013
I am writing a testing code that read CRS matrix M and rhs vector B from
two files and solve M*B=X.
I got error message indicating that I have segmentation fault but problem
disappeared after I removed MatDestroy(& M);
Another problem is that I am not sure if I should have
MatAssemblyBegin(M, MAT_FINAL_ASSEMBLY);
MatAssemblyEnd(M, MAT_FINAL_ASSEMBLY);
after
MatCreateSeqAIJWithArrays(PETSC_COMM_WORLD, nrow, ncol, rowptr, colptr,
mat, &M);
I attached my test code and hope someone can give me some pointers.
Kan
#include "petscksp.h"
#include "petscao.h"
#include "petsc.h"
#include "HYPRE.h"
#include "boost/timer/timer.hpp"
#include <string>
#include <iostream>
typedef boost::timer::cpu_timer Timer;
void P_Solve(const char * matrixFileName,
 const char * rhsFileName,
 const char * solFileName)
 Timer timer;
 PetscInitialize(PETSC_NULL,
 PETSC_NULL,
 PETSC_NULL,
 PETSC_NULL);
 Mat M; // initial matrix downloaded from disk
 Vec B; // initial RHS vector downloaded from disk
 Vec X; // initial guess=0/solution vector
 PC prec;
 KSP solver;
 FILE * fp;
 char temp[3];
 PetscInt nrow, ncol, nnz;
 PetscFOpen(PETSC_COMM_WORLD, matrixFileName, "r", &fp);
 fscanf(fp, "%s", temp); //#
 fscanf(fp, "%i %i %i", &nrow, &ncol, &nnz);
  PetscInt * rowptr = new PetscInt [nrow + 1];
 PetscInt * colptr = new PetscInt [nnz];
 PetscReal * mat = new PetscReal [nnz];
 for (int i = 0; i < nrow + 1; i++) {
 fscanf(fp, "%i", &rowptr[i]);
 for (int i = 0; i < nnz; i++) {
 fscanf(fp, "%i", &colptr[i]);
 fscanf(fp, "%lf", &mat[i]);
 fclose(fp);
mat, &M);
  // MatView(M, PETSC_VIEWER_STDOUT_WORLD);
 PetscFOpen(PETSC_COMM_WORLD, rhsFileName, "r", &fp);
  PetscReal * rhs = new PetscReal [nrow];
 PetscReal * x = new PetscReal [nrow];
  for (int i = 0; i < nrow; i++) {
 fscanf(fp, "%lf", &rhs[i]);
 fclose(fp);
 VecCreateSeqWithArray(PETSC_COMM_WORLD, 1, nrow, rhs, &B);
 // VecView(B, PETSC_VIEWER_STDOUT_WORLD);
 MatGetVecs(M, &X, NULL);
 KSPCreate(PETSC_COMM_WORLD, &solver);
 KSPSetFromOptions(solver);
  KSPConvergedReason reason;
  PetscReal rtol = 0;
 PetscReal atol = 0;
 PetscReal dtol = 0;
 PetscInt it = 0;
 PetscInt its = 0;
 KSPGetTolerances( solver, &rtol, &atol, &dtol, &it);
 rtol = 1e-6;
 it = 500;
 KSPSetTolerances( solver, rtol, atol, dtol, it);
  KSPSetOperators(solver, M, M, SAME_NONZERO_PATTERN);
  KSPSetType(solver, KSPBCGS);
 KSPSetPCSide(solver, PC_RIGHT); // right preconditioning
 KSPSetInitialGuessNonzero(solver,PETSC_FALSE);
  KSPGetPC(solver, &prec);
 PCSetType(prec, PCILU);
 KSPSetUp(solver);
 PCSetUp(prec);
 PCFactorGetMatrix(prec, &M);
 timer.resume();
 KSPSolve(solver,B,X);
 timer.stop();
 KSPGetConvergedReason(solver,&reason);
 if (reason==KSP_DIVERGED_INDEFINITE_PC) {
 PetscPrintf(PETSC_COMM_WORLD,"\nDivergence because of indefinite
preconditioner;\n");
 PetscPrintf(PETSC_COMM_WORLD,"Run the executable again but with
'-pc_factor_shift_type POSITIVE_DEFINITE' option.\n");
 } else if (reason<0) {
 PetscPrintf(PETSC_COMM_WORLD,"\nOther kind of divergence: this should not
happen. %d\n",reason);
 KSPGetIterationNumber(solver, &its);
 std::cout << "PETSc ITS = " << its << " "
 << "TIMES(SEC) = " << timer.elapsed().wall / 1.e9 << "\n";
 // VecView(X, PETSC_VIEWER_STDOUT_WORLD);
 VecGetArray(X, &x);
 PetscFOpen(PETSC_COMM_WORLD, solFileName, "w", &fp);
 fprintf(fp, "%.20e\n", x[i]);
 VecRestoreArray(X, &x);
 fclose(fp);
 KSPDestroy(& solver);
 VecDestroy(& B);
 VecDestroy(& X);
 MatDestroy(& M);
 if (rowptr == NULL) delete [] rowptr;
 if (colptr == NULL) delete [] colptr;
 if (mat == NULL) delete [] mat;
 if (rhs == NULL) delete [] rhs;
   PetscFinalize();
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130919/50446f01/attachment-0001.html>
