[petsc-users] Inverse matrix of MATMPIDENSE matrix
Joon Hee Choi choi240 at purdue.edu
Tue Sep 17 13:24:38 CDT 2013
Thank you for your reply.
The 10x10 matrix is the result of product between large matrices with 10 different processors. So I think I need to gather entries into a processor and create SeqDense matrix. Could you let me know what to do for gathering entries saved on several processors?
Sincerely,
Joon
----- Original Message -----
To: "Joon Hee Choi" <choi240 at purdue.edu>
Cc: petsc-users at mcs.anl.gov
Sent: Tuesday, September 17, 2013 2:10:15 PM
Subject: Re: [petsc-users] Inverse matrix of MATMPIDENSE matrix
 For parallel dense you need to use MatType MATELEMENTAL and configure PETSc with ../download-elemental
  Note that if N is 10 then it is insane to do the inverse in parallel. Just use SeqDense. If you want it on two processes just do it on one and send there result to the other or do it on both.
  Unless the matrix is at least 100s by 100s maybe more I don't see doing it in parallel as saving any time, rather it will be slower
   Barry
> However, I followed the manual using MatLUFactor() and MatMatSolve(). However, MatLUFactor() did not support MATMPIDENSE. If my code is wrong, then please let me know. My code is following:
> MatGetOrdering(invM2T, MATORDERINGNATURAL, &isr, &isc);
> MatFactorInfoInitialize(&info);
> MatLUFactor(invM2T, isr, isc, &info);
> MatMatSolve(invM2T, M1T, *M3T);
> If not so, then please let me know which function I have to use. Thank you.
> Sincerely,
> Joon
> From: "Barry Smith" <bsmith at mcs.anl.gov>
> Sent: Tuesday, September 17, 2013 7:59:42 AM
> http://www.mcs.anl.gov/petsc/documentation/faq.html#invertmatrix
> On Sep 17, 2013, at 1:07 AM, Joon Hee Choi <choi240 at purdue.edu> wrote:
>> Hello,
>> I want to get the inverse matrix of 10 x 10 MATMPIDENSE matrix. I know I cannot use MatLUFactor() for MATMPIDENSE. Is there any other method? Could you let me know the fastest way to get the inverse? Also, I don't want to rebuild or configure something for the inverse because I use petsc in my school server and I don't have permission to configure.
>> Thanks,
>> Joon
