[petsc-users] Petsc with open mpi 1.7
Tue Sep 17 11:42:55 CDT 2013
Are you using PETSc makefile format?
Please compare your link command with the the link command used for a
petsc example [say from "cd src/ksp/ksp/examples/tutorials && make
ex2"] - and look for differences with your link command.
We recommend using petsc makefile format to avoid such issues.
Satish
On Tue, 17 Sep 2013, Suraj Prabhakaran wrote:
> yes I also observed that. But still when I link petsc to a simple hello world example, I can see that the binary requires libmpi_f77 and libmpi_f90.
> Can you please compile the following snippet with mpicc and link it with petsc library, do a ldd on the binary and see if it asks for these 2 libraries or not?
> #include "stdio.h"
> int main()
> printf("hello world\n");
> return 0
> best,
> Suraj
> On Sep 17, 2013, at 6:25 PM, Satish Balay wrote:
> > I just attempted a build with openmpi 1.7  and 'make test' ran fine with it.
> > Satish
> > ./configure --download-openmpi=http://www.open-mpi.org/software/ompi/v1.7/downloads/openmpi-1.7.2.tar.gz
> > make all
> > make test
> >>> Hello,
> >>> I am trying to compile petsc with openmpi 1.7 version. I can compile and install petsc successfully. but my application doesn't run
> >> Do PETSc examples run?
> >> What do you get for 'make test'?
> >> If it doesn't work - send us the corresponding logs.
> >> Satish
> >>> since petsc is not able to find the libmpi_f77.so.1 and libmpi_f90.so.1.
> >>> The problem is, in openmpi 1.7 version, these fotran libraries are completely replaced with libmpi_mpifh.so
> >>> When I configure petsc with this mpi (I specifiy --with-mpi-dir option), I can see from the output that petsc only uses the libmpi_mpifh library rather than the other two. But still, when petsc is linked with my application, the binary ends up looking for libmpi_f90 and libmpi_f77, along with the correct libmpi_mpifh.
> >>> To really be sure, I also used a hello world program and linked it with all libraries to see which one really asks for libmpi_f90 and libmpi_f77 and it was for sure libpetsc.so.
> >>> Has anyone tried to compile and use petsc with openmpi 1.7 series?
> >>> Is there anything special I have to do for this case?
> >>> Best,
> >>> Suraj
> >>> Suraj Prabhakaran
> >>> German Research School for
> >>> Simulation Sciences GmbH
> >>> Laboratory for Parallel Progreamming
> >>> 52062 Aachen | Germany
> >>> Tel    	+49 241 80 99743
> >>> Fax   	+49 241 80 92742
> >>> EMail 	s.prabhakaran at grs-sim.de
> >>> Web  	www.grs-sim.de
> >>> Members:  Forschungszentrum Jülich GmbH | RWTH Aachen University
> >>> Registered in the commercial register of the local court of Düren (Amtsgericht Düren) under registration number HRB 5268
> >>> Registered office:  Jülich
> >>> Executive board:  Prof. Marek Behr Ph.D. | Prof. Dr. Sebastian M. Schmidt
> Suraj Prabhakaran
> Web  	www.grs-sim.de
