[petsc-users] Petsc with open mpi 1.7
Tue Sep 17 11:25:07 CDT 2013
I just attempted a build with openmpi 1.7  and 'make test' ran fine with it.
Satish
./configure --download-openmpi=http://www.open-mpi.org/software/ompi/v1.7/downloads/openmpi-1.7.2.tar.gz
make all
make test
On Tue, 17 Sep 2013, Satish Balay wrote:
> On Tue, 17 Sep 2013, Suraj Prabhakaran wrote:
> > Hello,
> > I am trying to compile petsc with openmpi 1.7 version. I can compile and install petsc successfully. but my application doesn't run
> Do PETSc examples run?
> What do you get for 'make test'?
> If it doesn't work - send us the corresponding logs.
> Satish
> > since petsc is not able to find the libmpi_f77.so.1 and libmpi_f90.so.1.
> > The problem is, in openmpi 1.7 version, these fotran libraries are completely replaced with libmpi_mpifh.so
> > When I configure petsc with this mpi (I specifiy --with-mpi-dir option), I can see from the output that petsc only uses the libmpi_mpifh library rather than the other two. But still, when petsc is linked with my application, the binary ends up looking for libmpi_f90 and libmpi_f77, along with the correct libmpi_mpifh.
> > To really be sure, I also used a hello world program and linked it with all libraries to see which one really asks for libmpi_f90 and libmpi_f77 and it was for sure libpetsc.so.
> > Has anyone tried to compile and use petsc with openmpi 1.7 series?
> > Is there anything special I have to do for this case?
> > Best,
> > Suraj
> > Suraj Prabhakaran
> > German Research School for
> > Simulation Sciences GmbH
> > Laboratory for Parallel Progreamming
> > 52062 Aachen | Germany
> > Tel    	+49 241 80 99743
> > Fax   	+49 241 80 92742
> > EMail 	s.prabhakaran at grs-sim.de
> > Web  	www.grs-sim.de
> > Members:  Forschungszentrum Jülich GmbH | RWTH Aachen University
> > Registered in the commercial register of the local court of Düren (Amtsgericht Düren) under registration number HRB 5268
> > Registered office:  Jülich
> > Executive board:  Prof. Marek Behr Ph.D. | Prof. Dr. Sebastian M. Schmidt
