[petsc-users] Petsc with open mpi 1.7
Suraj Prabhakaran s.prabhakaran at grs-sim.de
Tue Sep 17 10:57:44 CDT 2013
Hello,
I am trying to compile petsc with openmpi 1.7 version. I can compile and install petsc successfully. but my application doesn't run since petsc is not able to find the libmpi_f77.so.1 and libmpi_f90.so.1.
The problem is, in openmpi 1.7 version, these fotran libraries are completely replaced with libmpi_mpifh.so
When I configure petsc with this mpi (I specifiy --with-mpi-dir option), I can see from the output that petsc only uses the libmpi_mpifh library rather than the other two. But still, when petsc is linked with my application, the binary ends up looking for libmpi_f90 and libmpi_f77, along with the correct libmpi_mpifh.
To really be sure, I also used a hello world program and linked it with all libraries to see which one really asks for libmpi_f90 and libmpi_f77 and it was for sure libpetsc.so.
Has anyone tried to compile and use petsc with openmpi 1.7 series?
Is there anything special I have to do for this case?
Best,
Suraj
Suraj Prabhakaran
German Research School for
Simulation Sciences GmbH
Laboratory for Parallel Progreamming
52062 Aachen | Germany
Tel    	+49 241 80 99743
Fax   	+49 241 80 92742
EMail 	s.prabhakaran at grs-sim.de
Web  	www.grs-sim.de
Members:  Forschungszentrum Jülich GmbH | RWTH Aachen University
Registered in the commercial register of the local court of Düren (Amtsgericht Düren) under registration number HRB 5268
Registered office:  Jülich
Executive board:  Prof. Marek Behr Ph.D. | Prof. Dr. Sebastian M. Schmidt
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130917/3f419b32/attachment.html>
