[petsc-users] About MatGetOwnershipRange()
Joon Hee Choi choi240 at purdue.edu
Fri Sep 13 21:59:57 CDT 2013
Thank you for your reply. Actually, I succeeded in running with the PetscSpliOwnership() code that you gave to me. I think I didn't understand how to write a code in parallel. Thank you again.
----- Original Message -----
To: "Joon Hee Choi" <choi240 at purdue.edu>
Cc: petsc-users at mcs.anl.gov
Sent: Friday, September 13, 2013 5:34:33 PM
Subject: Re: [petsc-users] About MatGetOwnershipRange()
Joon Hee Choi <choi240 at purdue.edu> writes:
>>>Did you run in parallel?
>> Yes. I tested my code with 2 nodes and 4 ppn(processors per node).
>Then print what you are passing in and what you get back on each
>process.  The PetscSplitOwnership code is short.
>>>> Also, tuples are the total pairs of (row dimension, column dimension,
>>>> element), values of sparse matrix, which are read from a file.
>>>Using files this way is a massive bottleneck that you'll have to
>>>eliminate if you want your code to be scalable.
>> What do you mean a massive bottleneck?
>Writing to a file is at least 1000 times slower than accessing memory
>and it does not parallelize as well.
>> Actually, I succeeded in setting up the large matrix using seqaij type
>> and calculating products between huge matrices. However, I need to use
>> multiple machines because I have to run loops of the product many
>> times. And I am a novice of mpi.
>I'm not sure what you're asking, but you should create the matrices in
>memory, preferably in parallel and mostly where the entries will need to
>be stored.
>>>> The tuples are sorted and distributed.
>>>When you distribute, are you sure that each process really gets the
>>>entire row, or would it be possible to cut in the middle of a row?
>> I think each process gets the entire row. The following is the code for getting >>tuples from text file:
>>    ierr = PetscFOpen(PETSC_COMM_WORLD, inputFile, "r", &file); CHKERRQ(ierr);
>>    while (fscanf(file, "%d %d %d", &ii, &jj, &vv) == 3)
>>       tups.push_back(std::tr1::make_tuple (ii-1, jj-1, vv));
>>       if (ii > I) I = ii;
>>       if (jj > J) J = jj;
>>    ierr = PetscFClose(PETSC_COMM_WORLD, file); CHKERRQ(ierr);
>Nothing in this code snippet indicates that the row partition is non-overlapping.
