[petsc-users] how to simultaneously perform the partition of the unstructured mesh and reduction bandwidth of the resulting sparsematrix
Thu Sep 12 18:53:00 CDT 2013
丁老师 <ztdepyahoo at 163.com> writes:
> which petsc function perform the reordering of the matrix
MatGetOrdering() gives you the permutation vectors.
You should be doing this reordering with the *mesh*.  You can represent
mesh connectivity in a matrix and use MatPartitioning and
MatGetOrdering, but you should use the result to redistribute the mesh
before assembling the matrices containing your physics.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130912/4fa745a2/attachment.pgp>
