[petsc-users] MatGetRow and MatSetValues
Tue Sep 10 20:02:56 CDT 2013
"Jin, Shuangshuang" <Shuangshuang.Jin at pnnl.gov> writes:
> Hello, PETSc developers, I have a question regarding the usage of
> MatGetRow and MatSetValues.
> As shown in the piece of code below. I have a matrix A with n rows and
> N_Steps columns, for each time step I_Steps, I want to set A[x,
> I_Steps+1] = A[x, I_Steps] + someComputedValue;
> As I understand, in order to read A[x, I_Steps], I have to get the x's
> rows values in A by MatGetRow; In order to set the A[x, I_Steps+1], I
> have to use the MatSetValues.  And these operations require the
> MatAssemblyBegin and MatAssemblyEnd as well.
Yes.
> The problem is when I run the code, it only works when the number of
> processors equal to 1 or n. Otherwise, it's hanging there forever.
> I feel like the MatAssemblyBegin and MatAssemblyEnd may be the source
> of the problem.
MatAssemblyBegin and MatAssemblyEnd are collective, but you are not
calling them collectively when the process count is not 1 or evenly
dividing the problem size.
You can get all the values you need in one shot, then set all the values
with MatSetValues, then call assembly once.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130910/7706d15a/attachment-0001.pgp>
