[petsc-users] [PATCH 2/2] Call KSPSetFromOptions before setting fieldsplit-specific options
Sun Sep 8 11:17:23 CDT 2013
Umut Tabak <u.tabak at tudelft.nl> writes:
>> Looks like it's converging, albeit somewhat slowly, and your operator
>> scaling is terrible (not necessarily a problem, but full-space
>> fieldsplit methods work much better if you non-dimensionalize so that
>> the fields have similar scales).
> Indeed, something I am aware of,
> A00
> is ill-conditioned
> A11
> block is indefinite, even worse.
A11 indefinite could lead to the Schur complement being singular.  The
approach breaks down if that's the case.  A11 singular or negative
semi-definite is the standard case.
> I have been looking for some scaling options that might work but until
> now no success so far...
You need to read the literature for problems of your type.  There are a
few possible approaches to approximating the Schur complement.  The
splitting into blocks also might not be very good.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130908/5b8c10ee/attachment.pgp>
