[petsc-users] does kspsolve perform the reordering to reduce the bandwith of sparse matrix
Sun Sep 8 09:57:36 CDT 2013
   No. The reordering should be part of the process when setting up your mesh. That is you order the unknowns on the mesh properly and you do not need to reorder the matrix. Note that this improves not only the linear solver (a bit) but also improves the time of the mesh operations and function and Jacobian evaluations on the mesh.
On Sep 8, 2013, at 7:50 AM, 丁老师 <ztdepyahoo at 163.com> wrote:
