[petsc-users] [PATCH 2/2] Call KSPSetFromOptions before setting fieldsplit-specific options
Sun Sep 8 08:45:11 CDT 2013
Umut Tabak <u.tabak at tudelft.nl> writes:
>> Your splits were both the same, so the preconditioner was applied twice
>> to the first block and zero to the second block.  That made the
>> preconditioner singular.
> Dear Jed,
> Thanks a lot for your time and help, attached you can find a very
> challenging ill-conditioned problem:
> The first block comes from a structural problem and its size is 1490.
> The second block results from a fluid discretization and its size is
> 2432. So in total the coupled system is of size 3922. I created the
> blocks as given in the simple problem. However, with
> ./ex3 -pc_type fieldsplit -pc_fieldsplit_type schur
> -fieldsplit_1_pc_type icc -fieldsplit_1_ksp_type cg
> -fieldsplit_1_pc_type icc -fieldsplit_1_ksp_type minres
You have given nearly the same options twice.  Did you mean to control
the second split?
> -pc_fieldsplit_schur_factorization_type upper -ksp_monitor_true_residual
> The solver just hangs.
> The system is a symmetric system in this case given as
> A =
> A11 C
> C^T A22
> C is of size 1490X2432
> Could you please comment on this point for me, do I still have an error
> on the problem setup or on the usage of the options?
This is an invalid memory access and does not use ISCreateBlock correctly.
  PetscInt sz1 = 1490, sz2 = 2432;
  PetscInt bs = 2, n1=1, n2=1, inputindices[]={0}; /* block size is 2 */
  ISCreateBlock(PETSC_COMM_SELF,sz1,n1,inputindices,
                PETSC_COPY_VALUES,&is_row1);
  ISCreateBlock(PETSC_COMM_SELF,sz2,n2,inputindices+n1,
                PETSC_COPY_VALUES,&is_row2);
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130908/52130fc7/attachment.pgp>
