[petsc-users] [PATCH 2/2] Call KSPSetFromOptions before setting fieldsplit-specific options
Sun Sep 8 08:38:42 CDT 2013
Umut Tabak <u.tabak at tudelft.nl> writes:
>> Your splits were both the same,
> Some questions:
> + Splits represent different row and column blocks, right?
They should be different, though they can overlap (rarely what you
want).
> + And as far as I understand from you(maybe this is in the manual, I am
> not sure) and they should differ in size, right?
They may or may not be the same size, but if you look at what your code
actually did, it was creating two identical index sets (both only used
the first entry of your 'inputindices').
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130908/6066394d/attachment.pgp>
