[petsc-users] converting parallel matrix MATMPIJ to MATAIJ
Fri Sep 6 16:52:13 CDT 2013
On Fri, Sep 6, 2013 at 4:25 PM, Lukasz Kaczmarczyk <
Lukasz.Kaczmarczyk at glasgow.ac.uk> wrote:
> Hello,
> I solve system of eq. generated by finite element method.
> I  apply some projection matrix to stiffness matrix K,
> P=I-CT[(CTC)^-1]C
> where C  is some not square matrix.
> Resulting stiffness matrix K' has form
> K' = PT K P,
> with that at hand I solve problem K' *x = f'
> I manage to build shell matrix where I use sub ksp solver to get solution
> for (CTC)*b = C*x, where [ b = (CTC^-1*C*x)] . Using penalised matrix for
> preconditioner, where  K_prec = alpha*CCT + K, where alpha is penalty I can
> get solution in efficient way.
> Now I like to avoid penalty parameter, in order to do that I will need to
> apply penalty matrix for each individual finite element  matrix before it
> is assembled into K. No problem with that, using scattering it can be done.
> Problem is with  solution (CTC)*b = C*x, C and CTC matrices are parallel,
> since I have parallelised assembly functions, problem (CTC)*b = C*x need to
> be solved on each processor independently without communication. It is not
> problem, but to do that I need to transform C and CTC matrix form MATMPIAIJ
> to MATAIJ.
I think this might be what you want:
http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatGetSubMatrices.html
      Matt
> I know that MatConvert will not do it. I wonder it is any other way that
> form very beginning to assemble matrix C as a serial matrix.
> Regards,
> Lukasz
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130906/837bd03f/attachment.html>
