[petsc-users] confusion on the use of fieldsplit
    Umut Tabak
    u.tabak at tudelft.nl
    Fri Sep  6 10:48:45 CDT 2013
Dear all,
I am trying to use PETSc to solve linear systems where the operator
matrices are composed of blocks. But I am having hard time to set up the
PCFieldSplit, and a bit lost in the documentation. I sucessfully created
the matrix represented as
A
A11 A12
A21 A22
with
MatCreateNest(PETSC_COMM_WORLD,nr,NULL,nc,NULL,sub_matrices,&blockA);
but I could not understand really the following steps on how to
associate a KSP object with Field split properties to use different
conditioners on different blocks? In the mean time, continue on reading.
If you can outline the basic steps on how to construct this scheme and
submit analysis with basic command line options, that would of great help.
By the way, is not possible to output blockA that is assembled above on
the standard output?
Best regards,
Umut
