[petsc-users] Re-initializing petsc again
Suraj Prabhakaran suraj.prabhakaran at gmail.com
Wed Sep 4 04:49:23 CDT 2013
Dear satish,
The make test after installing petsc works fine. The compile command that produced the error is as follows.
mpicc -fPIC -c -g -Wshadow  -fomit-frame-pointer -Wall -DSPACE_DIM=2   -DNUMBER_EQN=4  -DNUMBER_SPECIES=1 -DNUMBER_TEMPERATURES=1 -DNUMBER_ENERGYMODES=1 -D_idealgas_ -DEOS_PERFECT_GAS  -DHAVE_FORTRAN_UNDERSCORE  -DPARALLEL  -include /Network/Servers/grsacx01.grs.rwth-aachen.de/Volumes/home/grsprabh/resmgmt/applications/Malleability/Quadflow/quadflow/Library/flow_solver/Source/Include/grspetsc_c.h -DPARFB  -DMPI_Get_address=MPI_Address -DMPI_Type_create_struct=MPI_Type_struct        -I/opt/petsc-3.4.2/include -I/opt/open-mpi/1.6/include -I/opt/metis/include -I/opt/parametis/include -I/Network/Servers/grsacx01.grs.rwth-aachen.de/Volumes/home/grsprabh/resmgmt/applications/Malleability/Quadflow/quadflow/Library/blitz++ -I/opt/cgns/include     -I/Network/Servers/grsacx01.grs.rwth-aachen.de/Volumes/home/grsprabh/resmgmt/applications/Malleability/Quadflow/quadflow/Program/Main -I/Network/Servers/grsacx01.grs.rwth-aachen.de/Volumes/home/grsprabh/resmgmt/applications/Malleability/Quadflow/quadflow/Library/mstlib -I/Network/Servers/grsacx01.grs.rwth-aachen.de/Volumes/home/grsprabh/resmgmt/applications/Malleability/Quadflow/quadflow/Library/mstlib/EssIGPMlib -I/Network/Servers/grsacx01.grs.rwth-aachen.de/Volumes/home/grsprabh/resmgmt/applications/Malleability/Quadflow/quadflow/Library/igpm_t_lib -I/Network/Servers/grsacx01.grs.rwth-aachen.de/Volumes/home/grsprabh/resmgmt/applications/Malleability/Quadflow/quadflow/Library/fluid_t_lib/xrms/include -I/Network/Servers/grsacx01.grs.rwth-aachen.de/Volumes/home/grsprabh/resmgmt/applications/Malleability/Quadflow/quadflow/Library/qigpmesh -I/Network/Servers/grsacx01.grs.rwth-aachen.de/Volumes/home/grsprabh/resmgmt/applications/Malleability/Quadflow/quadflow/Library/parallel -I/Network/Servers/grsacx01.grs.rwth-aachen.de/Volumes/home/grsprabh/resmgmt/applications/Malleability/Quadflow/quadflow/Library/flow_solver/Source/Include -I/Network/Servers/grsacx01.grs.rwth-aachen.de/Volumes/home/grsprabh/resmgmt/applications/Malleability/Quadflow/quadflow/Library/flow_solver/Source/Main/grid_generation_dir/Flower_Converter -I/Network/Servers/grsacx01.grs.rwth-aachen.de/Volumes/home/grsprabh/resmgmt/applications/Malleability/Quadflow/quadflow/Library/flow_solver/Source/Main/grid_generation_dir/Tau_Converter -I/Network/Servers/grsacx01.grs.rwth-aachen.de/Volumes/home/grsprabh/resmgmt/applications/Malleability/Quadflow/quadflow/Library/flow_solver/Source/Main/reconstruction_dir -I/Network/Servers/grsacx01.grs.rwth-aachen.de/Volumes/home/grsprabh/resmgmt/applications/Malleability/Quadflow/quadflow/Library/flow_solver/Source/Main/implicit_dir -I/Network/Servers/grsacx01.grs.rwth-aachen.de/Volumes/home/grsprabh/resmgmt/applications/Malleability/Quadflow/quadflow/Library/flow_solver/Source/Main/implicit_dir/matvec_2ndorder -I/Network/Servers/grsacx01.grs.rwth-aachen.de/Volumes/home/grsprabh/resmgmt/applications/Malleability/Quadflow/quadflow/Library/visual -I/Network/Servers/grsacx01.grs.rwth-aachen.de/Volumes/home/grsprabh/resmgmt/applications/Malleability/Quadflow/quadflow/Library/eos -I/Network/Servers/grsacx01.grs.rwth-aachen.de/Volumes/home/grsprabh/resmgmt/applications/Malleability/Quadflow/quadflow/Library/flow_solver/Source/Main/ANN_kd_tree Main/time_integration_dir/compute_tau_w_mean.c -o /Network/Servers/grsacx01.grs.rwth-aachen.de/Volumes/home/grsprabh/resmgmt/applications/Malleability/Quadflow/quadflow/install/tmp/Library/flow_solver/compute_tau_w_mean.o
Best,
Suraj
On Sep 4, 2013, at 5:14 AM, Satish Balay wrote:
> This is incomplete info.
> what compile command produced this error? And what do you get when you
> compile a petsc example with a petsc makefile? [complete output]
> Satish
> On Wed, 4 Sep 2013, Suraj Prabhakaran wrote:
>> Thanks a lot for the confirmation!!
>> I am now compiling it with 3.4.2, but I get a strange error and could be great if someone can just point out whats wrong. (Might be something stupid, but just in case...)
>> Thanks in advance!
>> Suraj
>> -------------------------------ERROR-----------------------------
>> In file included from /opt/petsc-3.4.2/include/petsc.h:8,
>>                 from Main/time_integration_dir/compute_tau_w_mean.c:91:
>> /opt/petsc-3.4.2/include/petscbt.h: In function ‘compute_tau_w_mean’:
>> /opt/petsc-3.4.2/include/petscbt.h:33: error: invalid storage class for function ‘PetscBTLength’
>> /opt/petsc-3.4.2/include/petscbt.h:38: error: invalid storage class for function ‘PetscBTMemzero’
>> /opt/petsc-3.4.2/include/petscbt.h:43: error: invalid storage class for function ‘PetscBTDestroy’
>> /opt/petsc-3.4.2/include/petscbt.h:48: error: invalid storage class for function ‘PetscBTLookup’
>> /opt/petsc-3.4.2/include/petscbt.h: In function ‘PetscBTLookup’:
>> /opt/petsc-3.4.2/include/petscbt.h:47: warning: declaration of ‘index’ shadows a global declaration
>> /usr/include/string.h:489: warning: shadowed declaration is here
>> /opt/petsc-3.4.2/include/petscbt.h:59: error: invalid storage class for function ‘PetscBTView’
>> /opt/petsc-3.4.2/include/petscbt.h:74: error: invalid storage class for function ‘PetscBTCreate’
>> /opt/petsc-3.4.2/include/petscbt.h:79: error: invalid storage class for function ‘PetscBTLookupSet’
>> /opt/petsc-3.4.2/include/petscbt.h: In function ‘PetscBTLookupSet’:
>> /opt/petsc-3.4.2/include/petscbt.h:78: warning: declaration of ‘index’ shadows a global declaration
>> /opt/petsc-3.4.2/include/petscbt.h:91: error: invalid storage class for function ‘PetscBTSet’
>> /opt/petsc-3.4.2/include/petscbt.h: In function ‘PetscBTSet’:
>> /opt/petsc-3.4.2/include/petscbt.h:90: warning: declaration of ‘index’ shadows a global declaration
>> /opt/petsc-3.4.2/include/petscbt.h:103: error: invalid storage class for function ‘PetscBTLookupClear’
>> /opt/petsc-3.4.2/include/petscbt.h: In function ‘PetscBTLookupClear’:
>> /opt/petsc-3.4.2/include/petscbt.h:102: warning: declaration of ‘index’ shadows a global declaration
>> /opt/petsc-3.4.2/include/petscbt.h:115: error: invalid storage class for function ‘PetscBTClear’
>> /opt/petsc-3.4.2/include/petscbt.h: In function ‘PetscBTClear’:
>> /opt/petsc-3.4.2/include/petscbt.h:114: warning: declaration of ‘index’ shadows a global declaration
>> In file included from /opt/petsc-3.4.2/include/petsc.h:9,
>> /opt/petsc-3.4.2/include/petscctable.h: In function ‘compute_tau_w_mean’:
>> /opt/petsc-3.4.2/include/petscctable.h:20: error: invalid storage class for function ‘PetscHash’
>> /opt/petsc-3.4.2/include/petscctable.h:40: error: invalid storage class for function ‘PetscTableAdd’
>> /opt/petsc-3.4.2/include/petscctable.h:83: error: invalid storage class for function ‘PetscTableAddCount’
>> /opt/petsc-3.4.2/include/petscctable.h:120: error: invalid storage class for function ‘PetscTableFind’
>> In file included from /opt/petsc-3.4.2/include/petscsnesfas.h:3,
>>                 from /opt/petsc-3.4.2/include/petsc.h:27,
>> /opt/petsc-3.4.2/include/petscsnes.h:585: error: invalid storage class for function ‘SNESGetSNESLineSearch’
>> /opt/petsc-3.4.2/include/petscsnes.h:586: error: invalid storage class for function ‘SNESSetSNESLineSearch’
>> Main/time_integration_dir/compute_tau_w_mean.c:223: warning: implicit declaration of function ‘wall_thermoquants’
>> Main/time_integration_dir/compute_tau_w_mean.c:155: warning: unused variable ‘iface_plus_one’
>> Main/time_integration_dir/compute_tau_w_mean.c:330: warning: value computed is not used
>> Main/time_integration_dir/compute_tau_w_mean.c:116: warning: unused variable ‘ierr’
>> Main/time_integration_dir/compute_tau_w_mean.c:111: warning: unused variable ‘icell’
>> Main/time_integration_dir/compute_tau_w_mean.c:105: warning: unused variable ‘mach’
>> /opt/petsc-3.4.2/include/petscts.h:328: warning: unused variable ‘TSRegisterAllCalled’
>> /opt/petsc-3.4.2/include/petscts.h:327: warning: unused variable ‘TSList’
>> /opt/petsc-3.4.2/include/petscts.h:168: warning: unused variable ‘DMTS_CLASSID’
>> /opt/petsc-3.4.2/include/petscts.h:167: warning: unused variable ‘TS_CLASSID’
>> /opt/petsc-3.4.2/include/petscts.h:163: warning: unused variable ‘TSExactFinalTimeOptions’
>> /opt/petsc-3.4.2/include/petscts.h:101: warning: unused variable ‘TSConvergedReasons’
>> /opt/petsc-3.4.2/include/petscts.h:80: warning: unused variable ‘TSEquationTypes’
>> /opt/petsc-3.4.2/include/petscsnesfas.h:19: warning: unused variable ‘SNESFASTypes’
>> /opt/petsc-3.4.2/include/petscsnes.h:679: warning: unused variable ‘SNESQNRestartTypes’
>> /opt/petsc-3.4.2/include/petscsnes.h:675: warning: unused variable ‘SNESQNScaleTypes’
>> /opt/petsc-3.4.2/include/petscsnes.h:667: warning: unused variable ‘SNESNCGTypes’
>> /opt/petsc-3.4.2/include/petscsnes.h:654: warning: unused variable ‘SNESNGMRESSelectTypes’
>> /opt/petsc-3.4.2/include/petscsnes.h:648: warning: unused variable ‘SNESNGMRESRestartTypes’
>> /opt/petsc-3.4.2/include/petscsnes.h:474: warning: unused variable ‘SNESLineSearch_Apply’
>> /opt/petsc-3.4.2/include/petscsnes.h:473: warning: unused variable ‘SNESLineSearchList’
>> /opt/petsc-3.4.2/include/petscsnes.h:472: warning: unused variable ‘SNESLineSearchRegisterAllCalled’
>> /opt/petsc-3.4.2/include/petscsnes.h:471: warning: unused variable ‘SNESLINESEARCH_CLASSID’
>> /opt/petsc-3.4.2/include/petscsnes.h:470: warning: unused variable ‘SNESList’
>> /opt/petsc-3.4.2/include/petscsnes.h:469: warning: unused variable ‘SNESRegisterAllCalled’
>> /opt/petsc-3.4.2/include/petscsnes.h:356: warning: unused variable ‘SNESNormTypes’
>> /opt/petsc-3.4.2/include/petscsnes.h:217: warning: unused variable ‘SNESConvergedReasons’
>> /opt/petsc-3.4.2/include/petscsnes.h:50: warning: unused variable ‘DMSNES_CLASSID’
>> /opt/petsc-3.4.2/include/petscsnes.h:49: warning: unused variable ‘SNES_CLASSID’
>> /opt/petsc-3.4.2/include/petsccharacteristic.h:44: warning: unused variable ‘CharacteristicList’
>> /opt/petsc-3.4.2/include/petsccharacteristic.h:43: warning: unused variable ‘CharacteristicRegisterAllCalled’
>> /opt/petsc-3.4.2/include/petscdmda.h:27: warning: unused variable ‘DMDABoundaryTypes’
>> /opt/petsc-3.4.2/include/petscpf.h:50: warning: unused variable ‘PFRegisterAllCalled’
>> /opt/petsc-3.4.2/include/petscpf.h:40: warning: unused variable ‘PF_CLASSID’
>> /opt/petsc-3.4.2/include/petscpf.h:12: warning: unused variable ‘PFList’
>> /opt/petsc-3.4.2/include/petscdm.h:34: warning: unused variable ‘DMRegisterAllCalled’
>> /opt/petsc-3.4.2/include/petscdm.h:33: warning: unused variable ‘DMList’
>> /opt/petsc-3.4.2/include/petscdm.h:11: warning: unused variable ‘DM_CLASSID’
>> /opt/petsc-3.4.2/include/petscdraw.h:239: warning: unused variable ‘PETSC_DRAWHG_CLASSID’
>> /opt/petsc-3.4.2/include/petscdraw.h:225: warning: unused variable ‘PETSC_DRAWSP_CLASSID’
>> /opt/petsc-3.4.2/include/petscdraw.h:206: warning: unused variable ‘PETSC_DRAWLG_CLASSID’
>> /opt/petsc-3.4.2/include/petscdraw.h:195: warning: unused variable ‘PETSC_DRAWAXIS_CLASSID’
>> /opt/petsc-3.4.2/include/petscdraw.h:26: warning: unused variable ‘PetscDrawList’
>> /opt/petsc-3.4.2/include/petscdraw.h:9: warning: unused variable ‘PETSC_DRAW_CLASSID’
>> /opt/petsc-3.4.2/include/petscmatlab.h:8: warning: unused variable ‘MATLABENGINE_CLASSID’
>> /opt/petsc-3.4.2/include/petscthreadcomm.h:35: warning: unused variable ‘PetscThreadCommReductionOps’
>> /opt/petsc-3.4.2/include/petscthreadcomm.h:32: warning: unused variable ‘PetscThreadCommList’
>> On Sep 3, 2013, at 9:03 PM, Satish Balay wrote:
>>> Also you would have to call MPI_Init() before the first PetscInitialize() [and
>>> similarly MPI_Finalize() after the last call to PetscFinalize()]
>>> Satish
>>> On Tue, 3 Sep 2013, Barry Smith wrote:
>>>>  There is a problem with the 3.3 series when reinitializing PETSc. Can you switch to PETSc 3.4 which properly supports calling PetscInitialize() several times.
>>>>  Barry
>>>> On Sep 3, 2013, at 1:58 PM, Suraj Prabhakaran <suraj.prabhakaran at gmail.com> wrote:
>>>>> Hello,
>>>>> Again, this relates to finalizing and initializing petsc in my application. I basically want to finalize petsc and initialize it again with a different MPI communicator. A rough sketch of my quite huge application is as follows.
>>>>> main()
>>>>> PetscInitialize()
>>>>> AOCreate()..
>>>>> AO operations..
>>>>> AODestroy()..
>>>>> PetscFinalize()
>>>>> PETSC_COMM_WORLD = A new communicator (which includes more processes)
>>>>> PetscInitialize()
>>>>> AOCreate()..
>>>>> AO operations..
>>>>> AODestroy()
>>>>> PetscFinalize()
>>>>> So after finalizing and initializing it back, I always get an error with one of the AO calls. Given below is the complete error I get when running with 8 procs. Can anyone give me a hint what the problem could be? I was told earlier, that finalizing and initializing petsc should not be a problem!
>>>>> Best,
>>>>> Suraj
>>>>> -------------------------ERROR starts here-------------------------------
>>>>> [0]PETSC ERROR: ------------------------------------------------------------------------
>>>>> [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation, probably memory access out of range
>>>>> [0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
>>>>> [0]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind[0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
>>>>> [0]PETSC ERROR: likely location of problem given in stack below
>>>>> [0]PETSC ERROR: ---------------------  Stack Frames ------------------------------------
>>>>> [0]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
>>>>> [0]PETSC ERROR:       INSTEAD the line number of the start of the function
>>>>> [0]PETSC ERROR:       is given.
>>>>> [0]PETSC ERROR: [0] PetscStrcmp line 414 /root/petsc/petsc-3.3-p7/src/sys/utils/str.c
>>>>> [0]PETSC ERROR: [0] PetscFListAdd line 202 /root/petsc/petsc-3.3-p7/src/sys/dll/reg.c
>>>>> [0]PETSC ERROR: [0] AORegister line 99 /root/petsc/petsc-3.3-p7/src/dm/ao/interface/aoreg.c
>>>>> [0]PETSC ERROR: [0] AORegisterAll line 28 /root/petsc/petsc-3.3-p7/src/dm/ao/interface/aoregall.c
>>>>> [0]PETSC ERROR: [0] AOInitializePackage line 49 /root/petsc/petsc-3.3-p7/src/dm/ao/interface/dlregisdm.c
>>>>> [0]PETSC ERROR: [0] AOCreate line 530 /root/petsc/petsc-3.3-p7/src/dm/ao/interface/ao.c
>>>>> [0]PETSC ERROR: [0] AOCreateBasicIS line 381 /root/petsc/petsc-3.3-p7/src/dm/ao/impls/basic/aobasic.c
>>>>> [0]PETSC ERROR: [0] AOCreateBasic line 336 /root/petsc/petsc-3.3-p7/src/dm/ao/impls/basic/aobasic.c
>>>>> [0]PETSC ERROR: --------------------- Error Message ------------------------------------
>>>>> [0]PETSC ERROR: Signal received!
>>>>> [0]PETSC ERROR: Petsc Release Version 3.3.0, Patch 7, Sat May 11 22:15:24 CDT 2013
>>>>> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
>>>>> [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
>>>>> [0]PETSC ERROR: See docs/index.html for manual pages.
>>>>> [0]PETSC ERROR: ./quadflow on a arch-linu named grsacc17 by grsprabh Tue Sep  3 20:56:21 2013
>>>>> [0]PETSC ERROR: Libraries linked from /opt/petsc3.3-1/lib
>>>>> [0]PETSC ERROR: Configure run at Mon Aug 19 13:56:50 2013
>>>>> [0]PETSC ERROR: Configure options --with-cc=mpicc --with-fc=mpif90 --with-cxx=mpiCC --download-f-blas-lapack --prefix=/opt/petsc3.3-1 --with-debugging
>>>>> [0]PETSC ERROR: User provided function() line 0 in unknown directory unknown file
>>>>> MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
>>>>> with errorcode 59.
>>>>> NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
>>>>> You may or may not see output from other processes, depending on
>>>>> exactly when Open MPI kills them.
>>>>> [1]PETSC ERROR: ------------------------------------------------------------------------
>>>>> [1]PETSC ERROR: Caught signal number 15 Terminate: Somet process (or the batch system) has told this process to end
>>>>> [1]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
>>>>> [1]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind[1]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
>>>>> [1]PETSC ERROR: likely location of problem given in stack below
>>>>> [1]PETSC ERROR: ---------------------  Stack Frames ------------------------------------
>>>>> [1]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
>>>>> [1]PETSC ERROR:       INSTEAD the line number of the start of the function
>>>>> [1]PETSC ERROR:       is given.
>>>>> [1]PETSC ERROR: --------------------- Error Message ------------------------------------
>>>>> [1]PETSC ERROR: Signal received!
>>>>> [1]PETSC ERROR: Petsc Release Version 3.3.0, Patch 7, Sat May 11 22:15:24 CDT 2013
>>>>> [1]PETSC ERROR: See docs/changes/index.html for recent updates.
>>>>> [1]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
>>>>> [1]PETSC ERROR: See docs/index.html for manual pages.
>>>>> [1]PETSC ERROR: ./quadflow on a arch-linu named grsacc17 by grsprabh Tue Sep  3 20:56:21 2013
>>>>> [1]PETSC ERROR: Libraries linked from /opt/petsc3.3-1/lib
>>>>> [1]PETSC ERROR: Configure run at Mon Aug 19 13:56:50 2013
>>>>> [1]PETSC ERROR: Configure options --with-cc=mpicc --with-fc=mpif90 --with-cxx=mpiCC --download-f-blas-lapack --prefix=/opt/petsc3.3-1 --with-debugging
>>>>> [1]PETSC ERROR: User provided function() line 0 in unknown directory unknown file
>>>>> [2]PETSC ERROR: ------------------------------------------------------------------------
>>>>> [2]PETSC ERROR: Caught signal number 15 Terminate: Somet process (or the batch system) has told this process to end
>>>>> [2]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
>>>>> [2]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind[2]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
>>>>> [2]PETSC ERROR: likely location of problem given in stack below
>>>>> [2]PETSC ERROR: ---------------------  Stack Frames ------------------------------------
>>>>> [2]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
>>>>> [2]PETSC ERROR:       INSTEAD the line number of the start of the function
>>>>> [2]PETSC ERROR:       is given.
>>>>> [2]PETSC ERROR: --------------------- Error Message ------------------------------------
>>>>> [2]PETSC ERROR: Signal received!
>>>>> [2]PETSC ERROR: Petsc Release Version 3.3.0, Patch 7, Sat May 11 22:15:24 CDT 2013
>>>>> [2]PETSC ERROR: See docs/changes/index.html for recent updates.
>>>>> [2]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
>>>>> [2]PETSC ERROR: See docs/index.html for manual pages.
>>>>> [2]PETSC ERROR: ./quadflow on a arch-linu named grsacc17 by grsprabh Tue Sep  3 20:56:21 2013
>>>>> [2]PETSC ERROR: Libraries linked from /opt/petsc3.3-1/lib
>>>>> [2]PETSC ERROR: Configure run at Mon Aug 19 13:56:50 2013
>>>>> [2]PETSC ERROR: Configure options --with-cc=mpicc --with-fc=mpif90 --with-cxx=mpiCC --download-f-blas-lapack --prefix=/opt/petsc3.3-1 --with-debugging
>>>>> [2]PETSC ERROR: User provided function() line 0 in unknown directory unknown file
>>>>> [3]PETSC ERROR: ------------------------------------------------------------------------
>>>>> [3]PETSC ERROR: Caught signal number 15 Terminate: Somet process (or the batch system) has told this process to end
>>>>> [3]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
>>>>> [3]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind[3]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
>>>>> [3]PETSC ERROR: likely location of problem given in stack below
>>>>> [3]PETSC ERROR: ---------------------  Stack Frames ------------------------------------
>>>>> [3]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
>>>>> [3]PETSC ERROR:       INSTEAD the line number of the start of the function
>>>>> [3]PETSC ERROR:       is given.
>>>>> [3]PETSC ERROR: --------------------- Error Message ------------------------------------
>>>>> [3]PETSC ERROR: Signal received!
>>>>> [3]PETSC ERROR: Petsc Release Version 3.3.0, Patch 7, Sat May 11 22:15:24 CDT 2013
>>>>> [3]PETSC ERROR: See docs/changes/index.html for recent updates.
>>>>> [3]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
>>>>> [3]PETSC ERROR: See docs/index.html for manual pages.
>>>>> [3]PETSC ERROR: ./quadflow on a arch-linu named grsacc17 by grsprabh Tue Sep  3 20:56:21 2013
>>>>> [3]PETSC ERROR: Libraries linked from /opt/petsc3.3-1/lib
>>>>> [3]PETSC ERROR: Configure run at Mon Aug 19 13:56:50 2013
>>>>> [3]PETSC ERROR: Configure options --with-cc=mpicc --with-fc=mpif90 --with-cxx=mpiCC --download-f-blas-lapack --prefix=/opt/petsc3.3-1 --with-debugging
>>>>> [3]PETSC ERROR: User provided function() line 0 in unknown directory unknown file
>>>>> [4]PETSC ERROR: ------------------------------------------------------------------------
>>>>> [4]PETSC ERROR: Caught signal number 15 Terminate: Somet process (or the batch system) has told this process to end
>>>>> [4]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
>>>>> [4]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind[4]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
>>>>> [4]PETSC ERROR: likely location of problem given in stack below
>>>>> [4]PETSC ERROR: ---------------------  Stack Frames ------------------------------------
>>>>> [4]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
>>>>> [4]PETSC ERROR:       INSTEAD the line number of the start of the function
>>>>> [4]PETSC ERROR:       is given.
>>>>> [4]PETSC ERROR: --------------------- Error Message ------------------------------------
>>>>> [4]PETSC ERROR: Signal received!
>>>>> [4]PETSC ERROR: Petsc Release Version 3.3.0, Patch 7, Sat May 11 22:15:24 CDT 2013
>>>>> [4]PETSC ERROR: See docs/changes/index.html for recent updates.
>>>>> [4]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
>>>>> [4]PETSC ERROR: See docs/index.html for manual pages.
>>>>> [4]PETSC ERROR: ./quadflow on a arch-linu named grsacc17 by grsprabh Tue Sep  3 20:56:21 2013
>>>>> [4]PETSC ERROR: Libraries linked from /opt/petsc3.3-1/lib
>>>>> [4]PETSC ERROR: Configure run at Mon Aug 19 13:56:50 2013
>>>>> [4]PETSC ERROR: Configure options --with-cc=mpicc --with-fc=mpif90 --with-cxx=mpiCC --download-f-blas-lapack --prefix=/opt/petsc3.3-1 --with-debugging
>>>>> [4]PETSC ERROR: User provided function() line 0 in unknown directory unknown file
>>>>> [5]PETSC ERROR: ------------------------------------------------------------------------
>>>>> [5]PETSC ERROR: Caught signal number 15 Terminate: Somet process (or the batch system) has told this process to end
>>>>> [5]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
>>>>> [5]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind[5]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
>>>>> [5]PETSC ERROR: likely location of problem given in stack below
>>>>> [5]PETSC ERROR: ---------------------  Stack Frames ------------------------------------
>>>>> [5]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
>>>>> [5]PETSC ERROR:       INSTEAD the line number of the start of the function
>>>>> [5]PETSC ERROR:       is given.
>>>>> [5]PETSC ERROR: --------------------- Error Message ------------------------------------
>>>>> [5]PETSC ERROR: Signal received!
>>>>> [5]PETSC ERROR: Petsc Release Version 3.3.0, Patch 7, Sat May 11 22:15:24 CDT 2013
>>>>> [5]PETSC ERROR: See docs/changes/index.html for recent updates.
>>>>> [5]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
>>>>> [5]PETSC ERROR: See docs/index.html for manual pages.
>>>>> [5]PETSC ERROR: ./quadflow on a arch-linu named grsacc17 by grsprabh Tue Sep  3 20:56:21 2013
>>>>> [5]PETSC ERROR: Libraries linked from /opt/petsc3.3-1/lib
>>>>> [5]PETSC ERROR: Configure run at Mon Aug 19 13:56:50 2013
>>>>> [5]PETSC ERROR: Configure options --with-cc=mpicc --with-fc=mpif90 --with-cxx=mpiCC --download-f-blas-lapack --prefix=/opt/petsc3.3-1 --with-debugging
>>>>> [5]PETSC ERROR: User provided function() line 0 in unknown directory unknown file
>>>>> [6]PETSC ERROR: ------------------------------------------------------------------------
>>>>> [6]PETSC ERROR: Caught signal number 15 Terminate: Somet process (or the batch system) has told this process to end
>>>>> [6]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
>>>>> [6]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind[6]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
>>>>> [6]PETSC ERROR: likely location of problem given in stack below
>>>>> [6]PETSC ERROR: ---------------------  Stack Frames ------------------------------------
>>>>> [6]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
>>>>> [6]PETSC ERROR:       INSTEAD the line number of the start of the function
>>>>> [6]PETSC ERROR:       is given.
>>>>> [6]PETSC ERROR: --------------------- Error Message ------------------------------------
>>>>> [6]PETSC ERROR: Signal received!
>>>>> [6]PETSC ERROR: Petsc Release Version 3.3.0, Patch 7, Sat May 11 22:15:24 CDT 2013
>>>>> [6]PETSC ERROR: See docs/changes/index.html for recent updates.
>>>>> [6]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
>>>>> [6]PETSC ERROR: See docs/index.html for manual pages.
>>>>> [6]PETSC ERROR: ./quadflow on a arch-linu named grsacc17 by grsprabh Tue Sep  3 20:56:21 2013
>>>>> [6]PETSC ERROR: Libraries linked from /opt/petsc3.3-1/lib
>>>>> [6]PETSC ERROR: Configure run at Mon Aug 19 13:56:50 2013
>>>>> [6]PETSC ERROR: Configure options --with-cc=mpicc --with-fc=mpif90 --with-cxx=mpiCC --download-f-blas-lapack --prefix=/opt/petsc3.3-1 --with-debugging
>>>>> [6]PETSC ERROR: User provided function() line 0 in unknown directory unknown file
>>>>> [7]PETSC ERROR: ------------------------------------------------------------------------
>>>>> [7]PETSC ERROR: Caught signal number 15 Terminate: Somet process (or the batch system) has told this process to end
>>>>> [7]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
>>>>> [7]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind[7]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
>>>>> [7]PETSC ERROR: likely location of problem given in stack below
>>>>> [7]PETSC ERROR: ---------------------  Stack Frames ------------------------------------
>>>>> [7]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
>>>>> [7]PETSC ERROR:       INSTEAD the line number of the start of the function
>>>>> [7]PETSC ERROR:       is given.
>>>>> [7]PETSC ERROR: --------------------- Error Message ------------------------------------
>>>>> [7]PETSC ERROR: Signal received!
>>>>> [7]PETSC ERROR: Petsc Release Version 3.3.0, Patch 7, Sat May 11 22:15:24 CDT 2013
>>>>> [7]PETSC ERROR: See docs/changes/index.html for recent updates.
>>>>> [7]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
>>>>> [7]PETSC ERROR: See docs/index.html for manual pages.
>>>>> [7]PETSC ERROR: ./quadflow on a arch-linu named grsacc17 by grsprabh Tue Sep  3 20:56:21 2013
>>>>> [7]PETSC ERROR: Libraries linked from /opt/petsc3.3-1/lib
>>>>> [7]PETSC ERROR: Configure run at Mon Aug 19 13:56:50 2013
>>>>> [7]PETSC ERROR: Configure options --with-cc=mpicc --with-fc=mpif90 --with-cxx=mpiCC --download-f-blas-lapack --prefix=/opt/petsc3.3-1 --with-debugging
>>>>> [7]PETSC ERROR: User provided function() line 0 in unknown directory unknown file
>>>>> mpiexec has exited due to process rank 0 with PID 2670 on
>>>>> node grsacc17 exiting improperly. There are two reasons this could occur:
>>>>> 1. this process did not call "init" before exiting, but others in
>>>>> the job did. This can cause a job to hang indefinitely while it waits
>>>>> for all processes to call "init". By rule, if one process calls "init",
>>>>> then ALL processes must call "init" prior to termination.
>>>>> 2. this process called "init", but exited without calling "finalize".
>>>>> By rule, all processes that call "init" MUST call "finalize" prior to
>>>>> exiting or it will be considered an "abnormal termination"
>>>>> This may have caused other processes in the application to be
>>>>> terminated by signals sent by mpiexec (as reported here).
