[petsc-users] Fwd: Fwd: How PETSc solves Ax=b in parallel
paul zhang paulhuaizhang at gmail.com
Tue Oct 22 15:12:49 CDT 2013
---------- Forwarded message ----------
Date: Tue, Oct 22, 2013 at 4:12 PM
Subject: Re: [petsc-users] Fwd: How PETSc solves Ax=b in parallel
To: Matthew Knepley <knepley at gmail.com>
One more question, can I solve the system in parallel?
On Tue, Oct 22, 2013 at 4:08 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Tue, Oct 22, 2013 at 3:04 PM, huaibao zhang <paulhuaizhang at gmail.com>wrote:
>> Thanks for the answer. It makes sense.
>> However, in my case, matrix A is huge and rather sparse, which also owns
>> a pretty good diagonal structure although there are some other elements are
>> nonzero. I have to  look for a better way to solve the system more
>> efficiently. If in parallel, it is even better.
>> Attached is an example for A's structure. The pink block is a matrix with
>> 10x10 elements. The row or column in my case can be in million size.
> The analytic character of the operator is usually more important than the
> sparsity structure for scalable solvers.
> The pattern matters a lot for direct solvers, and you should definitely
> try them (SuperLU_dist or MUMPS in PETSc).
> If they use too much memory or are too slow, then you need to investigate
> good preconditioners for iterative methods.
>    Matt
>> Thanks again.
>> Paul
>> Huaibao (Paul) Zhang
>> *Gas Surface Interactions Lab*
>> Department of Mechanical Engineering
>> University of Kentucky,
>> Lexington, KY, 40506-0503
>> *Office*: 216 Ralph G. Anderson Building
>> *Web*:gsil.engineering.uky.edu
>> On Oct 21, 2013, at 12:53 PM, Matthew Knepley <knepley at gmail.com> wrote:
>> On Mon, Oct 21, 2013 at 11:23 AM, paul zhang <paulhuaizhang at gmail.com>wrote:
>>> Hi Jed,
>>> Thanks a lot for your answer. It really helps. I built parts of the
>>> matrix on each processor, then collected them into a global one according
>>> to their global position. Actually I used two MPI function instead of the
>>> one in the example, where the local size, as well as the global size is
>>> given.
>>> VecCreateMPI and MatCreateMPIAIJ. It does not really matter right?
>>> My continuing question is since the iteration for the system is global.
>>> Is it more efficient if I solve locally instead. ie. solve parts on each of
>>> the processor instead of doing globally.
>> No, because this ignores the coupling between domains.
>>   Matt
>>> Thanks again,
>>> Paul
>>> On Mon, Oct 21, 2013 at 11:42 AM, Jed Brown <jedbrown at mcs.anl.gov>wrote:
>>>> paul zhang <paulhuaizhang at gmail.com> writes:
>>>> > I am using KSP, more specifically FGMRES method, with MPI to solve
>>>> Ax=b
>>>> > system. Here is what I am doing. I cut my computation domain into many
>>>> > pieces, in each of them I compute independently by solving fluid
>>>> equations.
>>>> > This has nothing to do with PETSc. Finally, I collect all of the
>>>> > information and load it to a whole A matrix.
>>>> I hope you build parts of this matrix on each processor, as is done in
>>>> the examples.  Note the range Istart to Iend here:
>>>> http://www.mcs.anl.gov/petsc/petsc-current/src/ksp/ksp/examples/tutorials/ex2.c.html
>>>> > My question is how PETSc functions work in parallel in my case. There
>>>> are
>>>> > two guesses to me. First, PETSc solves its own matrix for each domain
>>>> using
>>>> > local processor, although A is a global. For the values like number of
>>>> > iterations, solution vector, their numbers should have equaled to the
>>>> > number of processors I applied, but I get only one value for each of
>>>> them.
>>>> > The reason is that the processors must talk with each other once all
>>>> of
>>>> > their work is done, that is why I received the "all reduced" value.
>>>> This is
>>>> > more logical than my second guess.
>>>> It does not work because the solution operators are global, so to solve
>>>> the problem, the iteration must be global.
>>>> > In the second one, the system is solved in parallel too. But PETSc
>>>> function
>>>> > redistributes the global sparse matrix A to each of the processors
>>>> after
>>>> > its load is complete. That is to say now each processor may not solve
>>>> the
>>>> > its own partition matrix.
>>>> Hopefully you build the matrix already-distributed.  The default
>>>> _preconditioner_ is local, but the iteration is global.  PETSc does not
>>>> "redistribute" the matrix automatically, though if you call
>>>> MatSetSizes() and pass PETSC_DECIDE for the local sizes, PETSc will
>>>> choose them.
>>> Lexington,
>>> KY, 40506-0503*
>> experiments lead.
>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
Lexington,
KY, 40506-0503*
Lexington,
KY, 40506-0503*
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131022/9d513330/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131022/9d513330/attachment-0001.png>
