[petsc-users] signal received error; MatNullSpaceTest; Stokes flow solver with pc fieldsplit and schur complement
Bishesh Khanal bisheshkh at gmail.com
Thu Oct 17 07:43:17 CDT 2013
On Thu, Oct 17, 2013 at 1:07 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Thu, Oct 17, 2013 at 3:42 AM, Bishesh Khanal <bisheshkh at gmail.com>wrote:
>> On Wed, Oct 16, 2013 at 8:04 PM, Satish Balay <balay at mcs.anl.gov> wrote:
>>> On Wed, 16 Oct 2013, Matthew Knepley wrote:
>>> > You can also try running under MPICH, which can be valgrind clean.
>>> Actually --download-mpich would configure/install mpich with appropriate
>>> flags to be valgrind clean.
>> In my laptop (but not in the cluster, please look at the second part of
>> this reply below for the cluster case) that's how I configured petsc and
>> ran it under mpich. The following errors (which I do not understand what
>> they mean) was reported by valgrind when using the mpich of the petsc in my
>> laptop: Here is the command I used and the error:
> This is harmless, and as you can see it comes from gfortran initialization.
>>  (Note: petsc is an alias in my .bashrc: alias
>> petsc='/home/bkhanal/Documents/softwares/petsc-3.4.3/bin/petscmpiexec'
>> petsc -n 2 valgrind src/AdLemMain -pc_type fieldsplit -pc_fieldsplit_type
>> schur -pc_fieldsplit_dm_splits 0 -pc_fieldsplit_0_fields 0,1,2
>> -pc_fieldsplit_1_fields 3 -fieldsplit_0_pc_type hypre
>> -fieldsplit_0_ksp_converged_reason -ksp_converged_reason
>> ==3106== Memcheck, a memory error detector
>> ==3106== Copyright (C) 2002-2010, and GNU GPL'd, by Julian Seward et al.
>> ==3106== Using Valgrind-3.6.1 and LibVEX; rerun with -h for copyright info
>> ==3107== Memcheck, a memory error detector
>> ==3107== Copyright (C) 2002-2010, and GNU GPL'd, by Julian Seward et al.
>> ==3107== Using Valgrind-3.6.1 and LibVEX; rerun with -h for copyright info
>> ==3107== Command: src/AdLemMain -pc_type fieldsplit -pc_fieldsplit_type
>> ==3107==
>> ==3106== Command: src/AdLemMain -pc_type fieldsplit -pc_fieldsplit_type
>> ==3106==
>> ==3107== Conditional jump or move depends on uninitialised value(s)
>> ==3107==    at 0x32EEED9BCE: ??? (in /usr/lib64/libgfortran.so.3.0.0)
>> ==3107==    by 0x32EEED9155: ??? (in /usr/lib64/libgfortran.so.3.0.0)
>> ==3107==    by 0x32EEE185D7: ??? (in /usr/lib64/libgfortran.so.3.0.0)
>> ==3107==    by 0x32ECC0F195: call_init.part.0 (in /lib64/ld-2.14.90.so)
>> ==3107==    by 0x32ECC0F272: _dl_init (in /lib64/ld-2.14.90.so)
>> ==3107==    by 0x32ECC01719: ??? (in /lib64/ld-2.14.90.so)
>> ==3107==    by 0xE: ???
>> ==3107==    by 0x7FF0003EE: ???
>> ==3107==    by 0x7FF0003FC: ???
>> ==3107==    by 0x7FF000405: ???
>> ==3107==    by 0x7FF000410: ???
>> ==3107==    by 0x7FF000424: ???
>> ==3107==
>> ==3107==    at 0x32EEED9BD9: ??? (in /usr/lib64/libgfortran.so.3.0.0)
>> ==3107==
>> dmda of size: (8,8,8)
>>  using schur complement
>>  using user defined split
>>   Linear solve converged due to CONVERGED_ATOL iterations 0
>>   Linear solve converged due to CONVERGED_RTOL iterations 3
>> Linear solve converged due to CONVERGED_RTOL iterations 1
>> ==3106==
>> ==3106== HEAP SUMMARY:
>> ==3106==     in use at exit: 187,709 bytes in 1,864 blocks
>> ==3106==   total heap usage: 112,891 allocs, 111,027 frees, 19,838,487
>> bytes allocated
>> ==3106==
>> ==3107==
>> ==3107== HEAP SUMMARY:
>> ==3107==     in use at exit: 212,357 bytes in 1,870 blocks
>> ==3107==   total heap usage: 112,701 allocs, 110,831 frees, 19,698,341
>> bytes allocated
>> ==3107==
>> ==3106== LEAK SUMMARY:
>> ==3106==    definitely lost: 0 bytes in 0 blocks
>> ==3106==    indirectly lost: 0 bytes in 0 blocks
>> ==3106==      possibly lost: 0 bytes in 0 blocks
>> ==3106==    still reachable: 187,709 bytes in 1,864 blocks
>> ==3106==         suppressed: 0 bytes in 0 blocks
>> ==3106== Rerun with --leak-check=full to see details of leaked memory
>> ==3106==
>> ==3106== For counts of detected and suppressed errors, rerun with: -v
>> ==3106== ERROR SUMMARY: 0 errors from 0 contexts (suppressed: 2 from 2)
>> ==3107== LEAK SUMMARY:
>> ==3107==    definitely lost: 0 bytes in 0 blocks
>> ==3107==    indirectly lost: 0 bytes in 0 blocks
>> ==3107==      possibly lost: 0 bytes in 0 blocks
>> ==3107==    still reachable: 212,357 bytes in 1,870 blocks
>> ==3107==         suppressed: 0 bytes in 0 blocks
>> ==3107== Rerun with --leak-check=full to see details of leaked memory
>> ==3107==
>> ==3107== For counts of detected and suppressed errors, rerun with: -v
>> ==3107== Use --track-origins=yes to see where uninitialised values come
>> from
>> ==3107== ERROR SUMMARY: 2 errors from 2 contexts (suppressed: 2 from 2)
>> In the above example, the solver iterates and gives results.
>> Now the case in cluster: I had to configure petsc with the option:
>> --with-mpi-dir=/opt/openmpi-gcc/current/  , that's how the cluster
>> administrators asked me to install to get petsc running in many nodes of
>> the clusters. I had tried on my own to configure with --download-mpich in
>> the cluster too, but  could not succeed with some errors. If you really
>> think the errors could be from this configuration, I would retry to install
>> with the petscmpich; please let me know.
>> And the valgrind errors for the case where program terminates without
>> completing normally (big sized domain), it has following errors just before
>> abrupt termination:
>> ... lots of other errors and then warnings such as:
> This appears to be a bug in OpenMPI, which would not be all that
> surprising. First, you can try running
> in the debugger and extracting a stack trace from the SEGV.
Just to make sure that I understood what you said before I talk with the
cluster administrators:
The program crashes only for a bigger domain size. Even in the cluster, it
does not crash for the domain size up to a certain size.  So I need to run
in the debugger for the case when it crashes to get the stack trace from
the SEGV, right ? I do not know how to attach a debugger when submitting a
job to the cluster if that is possible at all! Or are you asking me to run
the program in the debugger in my laptop for the biggest size ? (I have not
tried running the code for the biggest size in my laptop fearing it might
take forever)
> Then you could
>   1) Get the admin to install MPICH
>   2) Try running a PETSc example on the cluster
>   3) Try running on another machine
>     Matt
>> ==55437== Warning: set address range perms: large range [0xc4369040,
>> 0xd6abb670) (defined)
>> ==55438== Warning: set address range perms: large range [0xc4369040,
>> 0xd6a6cd00) (defined)
>> ==37183== Warning: set address range perms: large range [0xc4369040,
>> 0xd69f57d8) (defined)
>> ==37182== Warning: set address range perms: large range [0xc4369040,
>> 0xd6a474f0) (defined)
>> mpiexec: killing job...
>> In between there are several errors such as:
>> ==59334== Use of uninitialised value of size 8
>> ==59334==    at 0xD5B3704: mca_pml_ob1_send_request_put
>> (pml_ob1_sendreq.c:1217)
>> ==59334==    by 0xE1EF01A: btl_openib_handle_incoming
>> (btl_openib_component.c:3092)
>> ==59334==    by 0xE1F03E9: btl_openib_component_progress
>> (btl_openib_component.c:3634)
>> ==59334==    by 0x81CF16A: opal_progress (opal_progress.c:207)
>> ==59334==    by 0x81153AC: ompi_request_default_wait_all (condition.h:92)
>> ==59334==    by 0xF4C25DD: ompi_coll_tuned_sendrecv_actual
>> (coll_tuned_util.c:54)
>> ==59334==    by 0xF4C91FD:
>> ompi_coll_tuned_allgatherv_intra_neighborexchange (coll_tuned_util.h:57)
>> ==59334==    by 0x8121783: PMPI_Allgatherv (pallgatherv.c:139)
>> ==59334==    by 0x5156D19: ISAllGather (iscoloring.c:502)
>> ==59334==    by 0x57A6B78: MatGetSubMatrix_MPIAIJ (mpiaij.c:3607)
>> ==59334==    by 0x532DB36: MatGetSubMatrix (matrix.c:7297)
>> ==59334==    by 0x5B97725: PCSetUp_FieldSplit(_p_PC*) (fieldsplit.c:524)
>>> Satish
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131017/d2ee8cad/attachment-0001.html>
