[petsc-users] --with-hypre-dir did not work for petsc configure in Win-7
Wed Nov 6 18:37:37 CST 2013
For one - the  --with-hypre-lib would be:
--with-hypre-lib=/cygdrive/c/Lib/hypre-2.8.0b-win64-release/lib/libHYPRE.a
However - it appears you built hypre with gcc - not icc [which I thought was your goal]
If gcc/gfortran would work - you might as well install hypre via petsc configure [--download-hypre]
Satish
> Satis,
> 1. hypre-2.9 did not build in Win-7 for some reason, so I still use hypre-2.8.0b.
> 2. I used CXXFLAGS="-O2 -MT" for hypre configure.
> 3. Tried --with-hypre-include and --with-hypre-lib but still got error:
>  ===============================================================================        TESTING: check from config.libraries(config/BuildSystem/config/libraries.py:145)        *******************************************************************************
> UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for details):
> --with-hypre-lib=['/cygdrive/c/Lib/hypre-2.8.0b-win64-release/lib'] and
> --with-hypre-include=['/cygdrive/c/Lib/hypre-2.8.0b-win64-release/include'] did not work
> 4. Content of hypre installation:
> $ ls -R /cygdrive/c/Lib/hypre-2.8.0b-win64-release
> /cygdrive/c/Lib/hypre-2.8.0b-win64-release:
> include  lib
> /cygdrive/c/Lib/hypre-2.8.0b-win64-release/include:
> Data.h                                       HYPRE_krylov.h                HYPRE_struct_mv.h   _hypre_IJ_mv.h       csr_block_matrix.h    par_csr_block_matrix.h
> HYPRE.h                                      HYPRE_lobpcg.h                HYPREf.h            _hypre_parcsr_ls.h   csr_matmultivec.h     par_csr_matmultivec.h
> HYPRE_DistributedMatrixPilutSolver_protos.h  HYPRE_matrix_matrix_protos.h  LLNL_FEI_Fei.h      _hypre_parcsr_mv.h   distributed_matrix.h  par_csr_pmvcomm.h
> HYPRE_DistributedMatrixPilutSolver_types.h   HYPRE_parcsr_ls.h             LLNL_FEI_Impl.h     _hypre_sstruct_ls.h  fei_defs.h            par_multivector.h
> HYPRE_FEI_includes.h                         HYPRE_parcsr_mv.h             LLNL_FEI_LSCore.h   _hypre_sstruct_mv.h  hypre_cfei.h          seq_multivector.h
> HYPRE_IJ_mv.h                                HYPRE_seq_mv.h                LLNL_FEI_Matrix.h   _hypre_struct_ls.h   interpreter.h         seq_mv.h
> HYPRE_LinSysCore.h                           HYPRE_sstruct_ls.h            LLNL_FEI_Solver.h   _hypre_struct_mv.h   krylov.h              temp_multivector.h
> HYPRE_MatvecFunctions.h                      HYPRE_sstruct_mv.h            LinearSystemCore.h  cfei-hypre.h         lobpcg.h
> HYPRE_config.h                               HYPRE_struct_ls.h             Lookup.h            cfei_hypre.h         multivector.h
> /cygdrive/c/Lib/hypre-2.8.0b-win64-release/lib:
> libHYPRE.a
> 5. I used compilation option -O3 for PETSc, but -O2 for hypre, can this be a problem?
> Thanks,
> Qin
> On Wednesday, November 6, 2013 4:11 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> 1. use latest hypre version - i.e
> https://computation.llnl.gov/casc/hypre/download/hypre-2.9.1a.tar.gz
> 2. Make sure its buit with -MT compiler option
> 3. specify hypre with --with-hypre-include and --with-hypre-lib options
> 4. send us the following [so we know whats there - and why configure is not finding it]
> Satish
> On Wed, 6 Nov 2013, Qin Lu wrote:
> > Hello,
> > I have built hypre-2.8.0b in Win-7 and have put the installlation under C:\Lib\hypre-2.8.0b-win64-release. Now I want to include it in my PETSc build but PETSc configure (within cygwin) gave an error message:
> > --with-hypre-dir=/cygdrive/c/Lib/hypre-2.8.0b-win64-release did not work
> > The configure.log is attached.
> > Many thanks for any suggestions,
> > Qin
