[petsc-users] How to pass data to PETSc
Fri Nov 1 09:17:02 CDT 2013
Ted Sariyski <tsariysk at craft-tech.com> writes:
>>> Q1: I have the stiffness matrix and the rhs vector assembled (outside)
>>> and in PETSc order. Do I still need to create a scatter:"ierr =
>>> VecScatterCreate(bb,isglobal,localX,islocal,&scatter)"?
>> What do you want to do with the Vec?
> Use KSP for solving a linear system.
It looks like your vectors are already distributed, so you don't need a
VecScatter.  If you were computing nonlinear residuals, you would
probably need to communicate with neighbors; VecScatter is a flexible
way to do that.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131101/3aa2d49b/attachment.pgp>
