[petsc-users] PC introduce errors at processor limits?
Tue May 7 09:23:05 CDT 2013
On Tue, May 7, 2013 at 9:20 AM, Frederik Treue <frtr at fysik.dtu.dk> wrote:
> Hi,
> I may be overlooking something very obvious here, but:
> I'm trying to solve a convection-diffusion problem. The method I use
> requires me to solve some Helmholtz and Poisson equations, which is the
> time consuming part. In order to reduce this time, I try to use
> preconditioners. However, no matter which preconditioner I use (I've
> tried PCJACOBI,PCBJACOBI,PCPBJACOBI,PCMG with 2 levels, galerkin) it
> introduces errors along the edges of the local domains when using
> multiple processors. These errors are small, but they don't converge to
> 0 as a function of resolution. I have checked with PCNONE, which
> eliminates the problem, but becomes unbearably slow.
> Is this somehow unavoidable? Or am I making some silly mistake? The code
> is somewhat complicated, but if desired, I can try to cook up a
> proof-of-(non)concept.
You have made a mistake somewhere, probably in your parallel function
evaluation.
For Poisson, see SNES ex5.
   Matt
> /Frederik Treue
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130507/488c23e2/attachment.html>
