[petsc-users] Trying to modify petrbf to use custom text file
Sat Mar 30 08:42:09 CDT 2013
On Sat, Mar 30, 2013 at 7:26 PM, Anil . <dasans at gmail.com> wrote:
> Matt,
> PetRBF runs properly on my system. But is the dev branch still required to
> run petRBF?
> Could my issues be associated with this?
No.
   Matt
> On Wed, Mar 27, 2013 at 9:50 AM, Matthew Knepley <knepley at gmail.com>wrote:
>> On Wed, Mar 27, 2013 at 3:13 PM, Anil . <dasans at gmail.com> wrote:
>>> Matt,
>>> Petsc Options I use to run are....
>>> mpirun -np 4 ./reader -pc_type asm -sub_pc_type lu -sub_mat_type dense
>>> -ksp_monitor -ksp_rtol 1e-13 -ksp_max_it 100 -vecscatter_alltoall
>>> -log_summary
>> 1) Always run with -ksp_view.
>> 2) The relative tolerance is probably too tight, but that is secondary
>> 3) Something is really wrong here. I am guessing something in the input
>> not what you want. If the interaction is
>>     truly short range, you would see significant drop in the residual on
>> the first iteration. First, take a look at the
>>     matrix using -mat_view draw:: -draw_pause -1. It should be banded.
>>     Matt
>>  Attached is the output..It also contains my petsc configuration
>>> On Wed, Mar 27, 2013 at 7:59 AM, Matthew Knepley <knepley at gmail.com>wrote:
>>>> On Wed, Mar 27, 2013 at 11:58 AM, Anil . <dasans at gmail.com> wrote:
>>>>> Matt,
>>>>> I am having around 3481 particles that are placed in an unstructured
>>>>> manner.
>>>>> Attached is the image showing the distribution.
>>>>  Show me your PETSc options, and try playing with the number of blocks.
>>>> If you look
>>>> at the PetRBF paper, we give guidance for choosing the sizes.
>>>>    Matt
>>>>> On Tue, Mar 26, 2013 at 11:45 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>>>>> On Mon, Mar 25, 2013 at 10:38 PM, Anil . <dasans at gmail.com> wrote:
>>>>>>> 1) Could not find the petrbf mailing list
>>>>>>> 2) Petrbf runs perfectly
>>>>>>> 3) Attached is the output with -ksp_view -ksp_monitor
>>>>>>> Just point me in the right direction. Issues might be very basic as
>>>>>>> I am starting to use Petsc
>>>>>> This output is a little strange. Some partitions have 0 entries. I am
>>>>>> guessing this problem is very
>>>>>> small. For PeRBF, it does turn out to be optimal to use small blocks,
>>>>>> but the block size depends
>>>>>> on your interaction scale. Right now you have 75 blocks, which might
>>>>>> be too many for your small
>>>>>> problem.
>>>>>>    Matt
>>>>>>> On Sat, Mar 23, 2013 at 2:18 AM, Matthew Knepley <knepley at gmail.com>wrote:
>>>>>>>> On Fri, Mar 22, 2013 at 10:58 PM, Anil . <dasans at gmail.com> wrote:
>>>>>>>>> Hi,
>>>>>>>>> I have a text file containing N rows.
>>>>>>>>> Each row with x,y,omega values.
>>>>>>>>> I am trying to interpolate this data onto a regular grid using
>>>>>>>>> petrbf
>>>>>>>>> But the KSP does not converge and am not able to find the reason.
>>>>>>>>> The code is available with the text files at
>>>>>>>>> https://www.dropbox.com/s/cypuwugbxo07kx0/rbf-interpolation.tar.gz
>>>>>>>>> I am very new to petsc and any direction how o proceed would be
>>>>>>>>> helpful.
>>>>>>>> 1) Did you mail the petrbf list?
>>>>>>>> 2) Could you run the petrbf examples?
>>>>>>>> 3) We cannot tell anything about convergence without the output of
>>>>>>>> -ksp_view -ksp_monitor.
>>>>>>>>    Matt
>>>>>>>>> Sincerely
>>>>>>>>> Anil Das P V
>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>>> experiments lead.
>>>>>>>> -- Norbert Wiener
>>>>>>> Sincerely
>>>>>>> Anil Das P V
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
>>>>> Sincerely
>>>>> Anil Das P V
>>>> experiments lead.
>>>> -- Norbert Wiener
>>> Sincerely
>>> Anil Das P V
>> experiments lead.
>> -- Norbert Wiener
> Sincerely
> Anil Das P V
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130331/16f2ff4d/attachment.html>
