[petsc-users] Slepc installation
Jose E. Roman jroman at dsic.upv.es
Wed Mar 27 08:01:48 CDT 2013
El 27/03/2013, a las 13:24, Sonya Blade escribió:
> Dear All,
> I've completed the installation of Petsc W/o trouble (at least I think I've done so because I didn't tested it). Now I'm trying to complete the installation of SLEPC. I set the enviroment variables for PETSC_DIR and SLPEC_DIR to point out to the location of installation folders of Petsc and Slepc respectively.
> When I run the ./configure from the CygWin terminal I receive the following error. I run the ./configure directly from the installed directory of Slepc,  so why it still complains Slepc_Dir is not the current directory.
> $ ./configure
> Checking environment...
> ERROR: SLEPC_DIR is not the current directory
> Regards,
Did you export the SLEPC_DIR variable?
Open the python console and try this:
>>> import os
>>> print os.path.realpath(os.getcwd())
>>> print os.path.realpath(os.environ['SLEPC_DIR'])
Both paths should be the same.
Jose
