[petsc-users] Trying to modify petrbf to use custom text file
Anil . dasans at gmail.com
Tue Mar 26 19:58:45 CDT 2013
Matt,
I am having around 3481 particles that are placed in an unstructured manner.
Attached is the image showing the distribution.
On Tue, Mar 26, 2013 at 11:45 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Mon, Mar 25, 2013 at 10:38 PM, Anil . <dasans at gmail.com> wrote:
>> 1) Could not find the petrbf mailing list
>> 2) Petrbf runs perfectly
>> 3) Attached is the output with -ksp_view -ksp_monitor
>> Just point me in the right direction. Issues might be very basic as I am
>> starting to use Petsc
> This output is a little strange. Some partitions have 0 entries. I am
> guessing this problem is very
> small. For PeRBF, it does turn out to be optimal to use small blocks, but
> the block size depends
> on your interaction scale. Right now you have 75 blocks, which might be
> too many for your small
> problem.
>    Matt
>> On Sat, Mar 23, 2013 at 2:18 AM, Matthew Knepley <knepley at gmail.com>wrote:
>>> On Fri, Mar 22, 2013 at 10:58 PM, Anil . <dasans at gmail.com> wrote:
>>>> Hi,
>>>> I have a text file containing N rows.
>>>> Each row with x,y,omega values.
>>>> I am trying to interpolate this data onto a regular grid using petrbf
>>>> But the KSP does not converge and am not able to find the reason.
>>>> The code is available with the text files at
>>>> https://www.dropbox.com/s/cypuwugbxo07kx0/rbf-interpolation.tar.gz
>>>> I am very new to petsc and any direction how o proceed would be helpful.
>>> 1) Did you mail the petrbf list?
>>> 2) Could you run the petrbf examples?
>>> 3) We cannot tell anything about convergence without the output of
>>> -ksp_view -ksp_monitor.
>>>    Matt
>>>> Sincerely
>>>> Anil Das P V
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
>> Sincerely
>> Anil Das P V
> experiments lead.
> -- Norbert Wiener
Sincerely
Anil Das P V
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130327/60e7e827/attachment-0001.html>
Type: application/postscript
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130327/60e7e827/attachment-0001.eps>
