[petsc-users] Any overheads of VecGetArray/VecRestoreArray?
Dominik Szczerba dominik at itis.ethz.ch
Tue Mar 26 13:44:03 CDT 2013
> VecNorm(X,NORM_2,&xnorm_before);
> for (each local element) {
>   VecGetArray(X,&x);
>   VecRestoreArray(X,&x);
> VecNorm(X,NORM_2,&xnorm_after);
> if some process has no local entries, it will think that X has not been
> modified and will not enter the MPI_Allreduce() to compute 'xnorm_after',
> which is deadlock.
> To avoid stuff like this, we recommend placing the VecGetArray() outside the
> loop, which is consistent with its designation as "logically collective".
Thanks a lot for the warning, so my feeling was right this is not a
good idea. However, this also means I better not use it in e.g. time
stepping loop, where I would call the function to assemble the global
coefficient matrix.
> You can use VecGetArrayRead() without worrying about this problem.
Sounds interesting, but I could not find this function so you are
probably referring to a dev version.
Dominik
