[petsc-users] Trying to modify petrbf to use custom text file
Anil . dasans at gmail.com
Mon Mar 25 06:38:19 CDT 2013
1) Could not find the petrbf mailing list
2) Petrbf runs perfectly
3) Attached is the output with -ksp_view -ksp_monitor
Just point me in the right direction. Issues might be very basic as I am
starting to use Petsc
On Sat, Mar 23, 2013 at 2:18 AM, Matthew Knepley <knepley at gmail.com> wrote:
> On Fri, Mar 22, 2013 at 10:58 PM, Anil . <dasans at gmail.com> wrote:
>> Hi,
>> I have a text file containing N rows.
>> Each row with x,y,omega values.
>> I am trying to interpolate this data onto a regular grid using petrbf
>> But the KSP does not converge and am not able to find the reason.
>> The code is available with the text files at
>> https://www.dropbox.com/s/cypuwugbxo07kx0/rbf-interpolation.tar.gz
>> I am very new to petsc and any direction how o proceed would be helpful.
> 1) Did you mail the petrbf list?
> 2) Could you run the petrbf examples?
> 3) We cannot tell anything about convergence without the output of
> -ksp_view -ksp_monitor.
>    Matt
>> Sincerely
>> Anil Das P V
> experiments lead.
> -- Norbert Wiener
Sincerely
Anil Das P V
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130325/1ca0ff62/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130325/1ca0ff62/attachment-0001.obj>
