[petsc-users] set block size on AMG systems
Sat Mar 23 14:37:46 CDT 2013
On Sun, Mar 24, 2013 at 6:35 AM, Nico Schlömer <nico.schloemer at gmail.com>wrote:
> http://www.mcs.anl.gov/petsc/petsc-dev/docs/manualpages/Mat/MatSetBlockSize.html
> Thanks!
> > For complex-valued problems, you're likely better off using complex
> numbers.
> Does PETSc support complex arithmetic natively? That'd be another
> reason for getting complex-value support into FEniCS.
Yes.
  Matt
> --Nico
> On Sat, Mar 23, 2013 at 8:29 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> > PCML, PCHYPRE, and PCGAMG pay attention to this parameter if no richer
> > information (like near-null spaces) is provided.
> numbers.
> > On Sat, Mar 23, 2013 at 2:25 PM, Nico Schlömer <nico.schloemer at gmail.com
> > wrote:
> >> Hi,
> >> I've got this linear system consisting of 2x2 blocks (acutally coming
> >> from a real-imaginary formulation of a complex-valued problem) and I'd
> >> like to precondition the linear solves with AMG. Things are already
> >> working well when taking the defaults, but I guess one could achieve
> >> way better when telling AMG about the 2x2 structure. Trilinos' ML does
> >> this by a parameter "PDE equations". -- Is there something comparable
> >> in the PETSc world?
> >> --Nico
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130324/d5f598b4/attachment.html>
