[petsc-users] KSP convergence problem
Wed Mar 20 15:49:21 CDT 2013
On Wed, Mar 20, 2013 at 3:43 PM, Mehrdad H Farahani
<mh.farahani at gmail.com>wrote:
> Besides, such diverging behavior occurs only with optimized build of Petsc.
Any more information on this? Can you make an optimized build using
COPTFLAGS='-O0 -g' and see if the problem is there too? Then use a debugger
to compare both versions.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130320/0b001add/attachment-0001.html>
