[petsc-users] Eigenvalue solver method in Petsc
Sun Mar 17 15:51:26 CDT 2013
On Sun, 17 Mar 2013, Sonya Blade wrote:
> > > >Cygwin is required to build PETSc, but not to use it.
> > > How about the MSys interface, which I've already installed.
> > Not currently, as far as I know.
> >whats your compiler requirement? And why?
> I use gfortran which ships with MinGW and with Msys I feel more
> comfortable.
Are you looking at sequential use of PETSc - or parallel? I see mpich
doesn't work with msys/mingw.
You can try an install of petsc with msys - and see if it works. If not send
us logs at petsc-maint.
[its possible things won't work - and you would have to use
cygwin/gfortran. Presumably it shouldn't conflict with your msys
install]
Satish
