[petsc-users] Eigenvalue solver method in Petsc
Sun Mar 17 12:05:18 CDT 2013
On Sun, Mar 17, 2013 at 11:59 AM, Sonya Blade <sonyablade2010 at hotmail.com>wrote:
> >SLEPc is the eigensolver package build on PETSc.
> >http://www.grycap.upv.es/slepc/
> >It is easy to install and use after installing PETSc.
> So the Petsc can not solve it on its own w/o Slepc?
PETSc is not an eigensolver package. You can write an eigensolver using
PETSc or you can use SLEPc.
> >Cygwin is required to build PETSc, but not to use it.
> How about the MSys interface, which I've already installed.
Not currently, as far as I know.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130317/72e9e2b0/attachment.html>
