[petsc-users] odd SNES behavior
Sat Mar 16 17:26:58 CDT 2013
The associated change to fieldsplit is in 'next':
https://bitbucket.org/petsc/petsc/commits/branch/jed/fieldsplit-use-amat
On Mon, Mar 11, 2013 at 8:28 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>   Sorry should be UseAmat
> On Mar 11, 2013, at 8:21 AM, "Mark F. Adams" <mark.adams at columbia.edu>
> wrote:
> > Humm, I'm not seeing PCSetUserAmat:
> > 09:14  ~/Codes/petsc-dev$ hg grep PCSetUserAmat
> > src/docs/website/documentation/changes/dev.html:26440:        <li>Merged
> PCBJacobiSetUseTrueLocal(), -pc_bjacobi_true_local, PCKSPSetUseTrue(),
> -pc_ksp_true, PCCompositeSetUseTrue() -pc_composite_true to
> PCSetUserAmat(), -pc_use_amat.
> > On Mar 8, 2013, at 10:27 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> >> On Mar 8, 2013, at 9:23 AM, "Mark F. Adams" <mark.adams at columbia.edu>
> wrote:
> >>>> I have merged PCBJacobiSetUseTrueLocal(), -pc_bjacobi_true_local,
> PCKSPSetUseTrue(), -pc_ksp_true, PCCompositeSetUseTrue() -pc_composite_true
> to PCSetUserAmat(), -pc_use_amat  in petsc-dev.
> >>>> Note that other preconditioners, PCMG,  PCFieldSplit, PCASM, PCGASM
> should adopt the same flag but I will leave that to Mark and Jed.
> >>> GAMG's problem comes from PCMG, do I need to do anything?
> >>  Yes, modify the PCMG :-).
> >>> other than make '-pc_use_amat false' because I would like to match
> hypre semantics by default.
> >>  It will be false by default.
> >>  Barry
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130316/ba676af8/attachment.html>
