[petsc-users] possible error
Nachiket Gokhale gokhalen at gmail.com
Wed Mar 13 16:21:32 CDT 2013
I am getting the error at the end of the email only in optimized mode.
Output of -on_error_attach_debugger and "where"  is at the end of this
email.  Running through valgrind in debug mode doesn't show up any
memory misuse on my part.  Does this seem to be something in petsc?
 -Nachiket
0]PETSC ERROR: ------------------------------------------------------------------------
[0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
probably memory access out of range
[0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[0]PETSC ERROR: or see
http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind[0]PETSC
ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to
find memory corruption errors
[0]PETSC ERROR: configure using --with-debugging=yes, recompile, link, and run
[0]PETSC ERROR: to get more information on the crash.
[0]PETSC ERROR: User provided function() line 0 in unknown directory
unknown file
[0]PETSC ERROR: PETSC: Attaching gdb to
/home/gokhale/WAIGEN/GDEB-WAIGEN2012/bin/waigen of pid 8458 on display
:47.0 on machine asd1.wai.com
#0  0x0000003caccaba50 in __nanosleep_nocancel () from /lib64/libc.so.6
#1  0x0000003caccab8e0 in sleep () from /lib64/libc.so.6
#2  0x00007f715f45f67f in PetscSleep ()
   from /opt/petsc/petsc-hg/linux-gcc-gpp-mpich-mumps-complex/lib/libpetsc.so
#3  0x00007f715f4982db in PetscAttachDebugger ()
#4  0x00007f715f49834b in PetscAttachDebuggerErrorHandler ()
#5  0x00007f715f498df8 in PetscError ()
#6  0x00007f715f49d67e in PetscSignalHandlerDefault ()
#7  0x00007f715f49d731 in PetscSignalHandler_Private(int) ()
#8  <signal handler called>
#9  0x00007f715f8bbcdb in MatTranspose_SeqAIJ(_p_Mat*, MatReuse, _p_Mat**) ()
#10 0x00007f715f57f05c in MatTranspose ()
#11 0x000000000040ce03 in waigensolveepsnull(_p_Mat**, _p_Mat**,
_p_Mat**, _p_Vec**, int*, int*, int*, int*, PetscBool) ()
#12 0x000000000040275f in main ()
