[petsc-users] odd SNES behavior
Mark F. Adams mark.adams at columbia.edu
Mon Mar 11 08:21:59 CDT 2013
Humm, I'm not seeing PCSetUserAmat:
09:14  ~/Codes/petsc-dev$ hg grep PCSetUserAmat
src/docs/website/documentation/changes/dev.html:26440:        <li>Merged PCBJacobiSetUseTrueLocal(), -pc_bjacobi_true_local, PCKSPSetUseTrue(), -pc_ksp_true, PCCompositeSetUseTrue() -pc_composite_true to PCSetUserAmat(), -pc_use_amat.
On Mar 8, 2013, at 10:27 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> On Mar 8, 2013, at 9:23 AM, "Mark F. Adams" <mark.adams at columbia.edu> wrote:
>>> I have merged PCBJacobiSetUseTrueLocal(), -pc_bjacobi_true_local, PCKSPSetUseTrue(), -pc_ksp_true, PCCompositeSetUseTrue() -pc_composite_true to PCSetUserAmat(), -pc_use_amat  in petsc-dev.
>>> Note that other preconditioners, PCMG,  PCFieldSplit, PCASM, PCGASM should adopt the same flag but I will leave that to Mark and Jed.
>> GAMG's problem comes from PCMG, do I need to do anything?
>   Yes, modify the PCMG :-).
>> other than make '-pc_use_amat false' because I would like to match hypre semantics by default.
>   It will be false by default.
>   Barry
