[petsc-users] compiling with complex
Manav Bhatia bhatiamanav at gmail.com
Wed Mar 6 09:39:02 CST 2013
Thanks Jed.
3.3 compiles fine on my machine with complex support. However, the reason I am not using it is the modified NaN handling between 3.1 and 3.3.
Seems like for a vector with some NaNs 3.1 returned an L2 norm as a NaN. But, 3.3 throws an exception. I would prefer to handle the NaN occurrence within my code, which is still forcing me to stick to 3.1.
Is there a way to turn off this behavior in 3.3? Any other suggestions would be welcome.
Manav
On Mar 6, 2013, at 10:34 AM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> On Wed, Mar 6, 2013 at 9:30 AM, Manav Bhatia <bhatiamanav at gmail.com> wrote:
> Hi,
>    I am attempting to build pets 3.1-p8 on a mac 10.8 machine with complex support, but am running into trouble at compile time. Attached is the make.log.
> It looks like your mpi.h is messed up, but we can't support such old versions of PETSc.
> Please upgrade to petsc-3.3 and send configure.log and make.log to petsc-maint at mcs.anl.gov if you have problems.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130306/58675042/attachment.html>
