[petsc-users] DMMeshCreateMeshFromAdjacency
Dharmendar Reddy dharmareddy84 at gmail.com
Sun Mar 3 18:03:35 CST 2013
Sorry, I will try to present the problem in more detial.
So i am trying to mesh a material region. The material is usually a crystal
with atoms located as per the lattice defining the crystal. See for example
the attached image which has silicon atoms (spheres) in the crystal unit
cell which is a cuboid.
Now if i have a cuboid region with 10 unit cells each in x, y and z
direction. I need to mesh this region such that I have mesh nodes at atom
locations. The can be more mesh nodes than the atom locations.
On Sun, Mar 3, 2013 at 5:45 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Sun, Mar 3, 2013 at 6:41 PM, Dharmendar Reddy <dharmareddy84 at gmail.com>wrote:
>> Let say I create triangular mesh in a square: (0,0) (0,1) (1,1) (0,1)
>> I want (0,0.25) and (0.25,0) to be among the mesh nodes. It can have
>> other nodes.
> These explanations are too short. From the above, all I understand is that
> you would get
> a line between (0, 1/4) and (1/4, 0).
>    Matt
>> On Sun, Mar 3, 2013 at 5:29 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>> On Sun, Mar 3, 2013 at 5:04 PM, Dharmendar Reddy <
>>> dharmareddy84 at gmail.com> wrote:
>>>> Hello,
>>>>         We use cratisian mesh for certain problems only. The user gives
>>>> the mesh file as one of the inputs. I do not know a-priori what mesh is
>>>> created.
>>>> On a related note, I am solving a system of equations where i need to
>>>> use a fine cartisian mesh for one equation (Schrodinger)  but i would
>>>> prefer a coarse traiangular or tetrahedral element mesh for another
>>>> eqaution(Poisson). Is there an interface to interpolate data from one mesh
>>>> to another?
>>> There is an interface, which is just a Mat, but there is no
>>> infrastructure for calculating it.
>>>> If i create a DM with a coarse mesh, Can i give the mesh a set of
>>>> vertices such that after re meshing the DM has the given vertices as mesh
>>>> nodes ? I tried using the gmsh to create a mesh with give set of vertices
>>>> inside a region but had no success.
>>> I do not understand the question.
>>>   Thanks,
>>>      Matt
>>>> Thanks
>>>> Reddy
>>>> On Sun, Mar 3, 2013 at 3:44 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>>>> On Sun, Mar 3, 2013 at 3:48 PM, Dharmendar Reddy <
>>>>>> So i should use petsc-dev ? I will try that.
>>>>>> I there any way i can have access to submesh? Consider a this
>>>>>> scenario.
>>>>>> I have a two dimensional mesh in a rectangle with a uniform deltaX
>>>>>> and deltaY gridding. Is there any way i can get submesh at say x =
>>>>>> (i-1)*deltaX where  say i = 1 to N. The dofs on the submesh will should be
>>>>>> mapped to dofs on the original mesh. The submesh in this case will be  a 1D
>>>>>> mesh along y-axis.
>>>>> 1) If you have a Cartesian mesh, use DMDA. This is no point in an
>>>>> unstructured mesh.
>>>>> 2) Yes, you can extract a submesh based upon labeled vertices using
>>>>> DMPlexCreateSubmesh(). It will have
>>>>>     a map between points in the submesh and original mesh.
>>>>>> I can create each DM with input celllist and create maps after that
>>>>>> but i am wondering if this can be done via DMgetsubDM kind of call ?
>>>>>     Matt
>>>>>> Thanks
>>>>>> Reddy
>>>>>> On Sun, Mar 3, 2013 at 2:11 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>>>>>> On Sun, Mar 3, 2013 at 2:37 PM, Dharmendar Reddy <
>>>>>>>> Hello,
>>>>>>>>          Thanks. I will have the code compiled with-cxx and
>>>>>>>> with-sieve.
>>>>>>>> The error is understandable when i look at the following line from
>>>>>>>> meshcreate.c
>>>>>>>> 312:   if (interpolate) {SETERRQ <http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/SETERRQ.html#SETERRQ>(comm, PETSC_ERR_SUP, "Interpolation (creation of faces and edges) is not yet supported.");}
>>>>>>>> Any idea if this feature will be implimented? I am trying to import mesh from gmsh.
>>>>>>>> I have a Fortran code which will genrate list for faces and edges for a given mesh.
>>>>>>>> Is there a DMMEsh interface through which i can input list of edges and faces ?
>>>>>>> DMMesh was an initial implementation of these ideas, but did not
>>>>>>> interface well with
>>>>>>> solvers, so it has been rewritten in C as DMPlex. The interface is
>>>>>>> almost exactly the
>>>>>>> same, and if you want increased functionality I would encourage you
>>>>>>> to switch. For
>>>>>>> example, DMMeshCreateMeshFromAdjacency() becomes
>>>>>>>   DMPlexCreateFromCellList()
>>>>>>> and you can follow this with
>>>>>>>   DMInterpolate()
>>>>>>> to automatically create the edges and faces.
>>>>>>>   Thanks,
>>>>>>>      Matt
>>>>>>>> Thanks
>>>>>>>> Reddy
>>>>>>>> On Sun, Mar 3, 2013 at 12:23 AM, Satish Balay <balay at mcs.anl.gov>wrote:
>>>>>>>>> BTW: I don't get compile errors with this code using petsc-3.3
>>>>>>>>> built with:
>>>>>>>>>  --with-clanguage=cxx --with-sieve=1 --with-boost=1
>>>>>>>>> [the code fails to run though..]
>>>>>>>>> Satish
>>>>>>>>> asterix:/home/balay/download-pine>make
>>>>>>>>> PETSC_DIR=/home/balay/petsc-dist-test PETSC_ARCH=asterix64-sieve
>>>>>>>>> petscDMTest_v2
>>>>>>>>> /home/balay/soft/linux64/mpich2-1.1/bin/mpif90 -c  -fPIC -Wall
>>>>>>>>> -Wno-unused-variable -Wno-unused-dummy-argument -g
>>>>>>>>> -I/home/balay/petsc-dist-test/include
>>>>>>>>> -I/home/balay/petsc-dist-test/asterix64-sieve/include
>>>>>>>>> -I/home/balay/petsc-dist-test/include/sieve
>>>>>>>>> -I/home/balay/soft/linux64/mpich2-1.1/include
>>>>>>>>> -I/home/balay/soft/mpich2-1.5/include    -o petscDMTest_v2.o
>>>>>>>>> petscDMTest_v2.F90
>>>>>>>>> /home/balay/soft/linux64/mpich2-1.1/bin/mpif90 -fPIC -Wall
>>>>>>>>> -Wno-unused-variable -Wno-unused-dummy-argument -g   -o petscDMTest_v2
>>>>>>>>> petscDMTest_v2.o
>>>>>>>>>  -Wl,-rpath,/home/balay/petsc-dist-test/asterix64-sieve/lib
>>>>>>>>> -L/home/balay/petsc-dist-test/asterix64-sieve/lib  -lpetsc -lX11 -lpthread
>>>>>>>>> -llapack -lblas -lm -Wl,-rpath,/home/balay/soft/mpich2-1.5/lib
>>>>>>>>> -L/home/balay/soft/mpich2-1.5/lib
>>>>>>>>> -Wl,-rpath,/usr/lib/gcc/x86_64-redhat-linux/4.7.2
>>>>>>>>> -L/usr/lib/gcc/x86_64-redhat-linux/4.7.2 -lmpichf90 -lgfortran -lm
>>>>>>>>> -lgfortran -lm -lquadmath -lm -lmpichcxx -lstdc++ -ldl -lmpich -lopa -lmpl
>>>>>>>>> -lrt -lgcc_s -ldl
>>>>>>>>> /usr/bin/rm -f petscDMTest_v2.o
>>>>>>>>> asterix:/home/balay/download-pine>./petscDMTest_v2
>>>>>>>>> [0]PETSC ERROR: --------------------- Error Message
>>>>>>>>> [0]PETSC ERROR: No support for this operation for this object type!
>>>>>>>>> [0]PETSC ERROR: Interpolation (creation of faces and edges) is not
>>>>>>>>> yet supported.!
>>>>>>>>> [0]PETSC ERROR:
>>>>>>>>> [0]PETSC ERROR: Petsc Release Version 3.3.0, Patch 6, unknown
>>>>>>>>> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
>>>>>>>>> [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
>>>>>>>>> [0]PETSC ERROR: See docs/index.html for manual pages.
>>>>>>>>> [0]PETSC ERROR:
>>>>>>>>> [0]PETSC ERROR: ./petscDMTest_v2 on a asterix64 named asterix by
>>>>>>>>> balay Sun Mar  3 00:21:29 2013
>>>>>>>>> [0]PETSC ERROR: Libraries linked from
>>>>>>>>> [0]PETSC ERROR: Configure run at Sun Mar  3 00:15:25 2013
>>>>>>>>> [0]PETSC ERROR: Configure options
>>>>>>>>> --with-mpi-dir=/home/balay/soft/linux64/mpich2-1.1
>>>>>>>>> --with-shared-libraries=1 --with-clanguage=cxx --with-sieve=1
>>>>>>>>> PETSC_ARCH=asterix64-sieve --with-boost=1
>>>>>>>>> [0]PETSC ERROR:
>>>>>>>>> [0]PETSC ERROR: DMMeshCreateMeshFromAdjacency() line 312 in
>>>>>>>>> /home/balay/petsc-dist-test/src/dm/impls/mesh/meshcreate.c
>>>>>>>>>  Surcessfully Loaded mesh into DM
>>>>>>>>> On Sat, 2 Mar 2013, Satish Balay wrote:
>>>>>>>>> > Fortran compiler doesn't care about presence or absence of
>>>>>>>>> interface
>>>>>>>>> > defintions. If they exist - then it does extra prototype checks.
>>>>>>>>> If
>>>>>>>>> > they don't exist - it assumes f77 and chugs along].
>>>>>>>>> > Did you build petsc with sieve [and cxx]?  send make.log for this
>>>>>>>>> > petsc build. Also what do you get for:
>>>>>>>>> > nm -Ao libpetsc.a |grep -i DMMeshCreateMeshFromAdjacency
>>>>>>>>> > You can followup this issue [with logs] on petsc-maint.
>>>>>>>>> > Satish
>>>>>>>>> > On Sat, 2 Mar 2013, Dharmendar Reddy wrote:
>>>>>>>>> > > As you said, I do not need, PETSC_USE_FORTRAN_INTERFACES. The
>>>>>>>>> interface to
>>>>>>>>> > > dmmeshcreatefromadjacency is not defined in
>>>>>>>>> > > finclude/ftn-custom/petscdmmesh.h90
>>>>>>>>> > > it is only defined in
>>>>>>>>> > > finclude/ftn-auto/petscdmmesh.h90
>>>>>>>>> > > On Sat, Mar 2, 2013 at 7:51 PM, Dharmendar Reddy <
>>>>>>>>> > > > Hello,
>>>>>>>>> > > >         Sorry, I was going to create a test case. Anyways
>>>>>>>>> here is the
>>>>>>>>> > > > error message
>>>>>>>>> > > > petscDMTest_v2.o: In function `MAIN__':
>>>>>>>>> > > > petscDMTest_v2.F90:(.text+0x354): undefined reference to
>>>>>>>>> > > > `dmmeshcreatemeshfromad
>>>>>>>>> > > > jacency_'
>>>>>>>>> > > > make: [testDMMesh] Error 1 (ignored)
>>>>>>>>> > > > I have attached a test case and makefile.  make all should
>>>>>>>>> gen rate the
>>>>>>>>> > > > executable.
>>>>>>>>> > > > Thanks
>>>>>>>>> > > > Reddy
>>>>>>>>> > > > On Sat, Mar 2, 2013 at 7:10 PM, Satish Balay <
>>>>>>>>> > > >> > Hello,
>>>>>>>>> > > >> >         I am trying to use DMMeshCreateMeshFromAdjacency
>>>>>>>>> in a Fortran
>>>>>>>>> > > >> code.
>>>>>>>>> > > >> > I get undefined reference error.
>>>>>>>>> > > >> What error? please copy/paste
>>>>>>>>> > > >> > I include the following file in my program
>>>>>>>>> > > >> > #include "finclude/petsc.h90"
>>>>>>>>> > > >> > I see that fortran interface to
>>>>>>>>> DMMeshCreateMeshFromAdjacency is defined
>>>>>>>>> > > >> > only in
>>>>>>>>> > > >> > I am not able to figure out if
>>>>>>>>> PETSC_USE_FORTRAN_INTERFACES is defined.
>>>>>>>>> > > >> I
>>>>>>>>> > > >> > did not compile the code. I am runing the code on TACC
>>>>>>>>> stampede. I tried
>>>>>>>>> > > >> > adding
>>>>>>>>> > > >> > #define PETSC_USE_FORTRAN_INTERFACES 1
>>>>>>>>> > > >> > in my program before the petsc inlcude line but i still
>>>>>>>>> get error.
>>>>>>>>> > > >> 1. again 'get error' doesn't tell us anything.
>>>>>>>>> > > >> And you shouldn't need PETSC_USE_FORTRAN_INTERFACES to use
>>>>>>>>> > > >> Satish
>>>>>>>>> > > >> > Thanks
>>>>>>>>> > > >> > Reddy
>>>>>>>>> > > > Dharmendar Reddy Palle
>>>>>>>>> > > > Graduate Student
>>>>>>>>> > > > Microelectronics Research center,
>>>>>>>>> > > > University of Texas at Austin,
>>>>>>>>> > > > 10100 Burnet Road, Bldg. 160
>>>>>>>>> > > > MER 2.608F, TX 78758-4445
>>>>>>>>> > > > e-mail: dharmareddy84 at gmail.com
>>>>>>>>> > > > Phone: +1-512-350-9082
>>>>>>>>> > > > United States of America.
>>>>>>>>> > > > Homepage: https://webspace.utexas.edu/~dpr342
>>>>>>>> Graduate Student
>>>>>>> What most experimenters take for granted before they begin their
>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>> experiments lead.
>>>>>>> -- Norbert Wiener
>>>>>> Graduate Student
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>>>> Graduate Student
>>> experiments lead.
>>> -- Norbert Wiener
>> Graduate Student
> experiments lead.
> -- Norbert Wiener
Graduate Student
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130303/5db11db3/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130303/5db11db3/attachment-0001.png>
