[petsc-users] MATNEST with shell matrices
Fri Mar 1 13:07:36 CST 2013
On Thu, Feb 28, 2013 at 3:39 PM, Amneet Bhalla <mail2amneet at gmail.com>wrote:
> I am all for doing things the legal way :-)
> Where should this routine be added and how should it look like for shell
> vectors? I had assumed that
> such changes should be done in user defined MatGetVecs routine. Clearly
> this is not happening.
Please explain.
> Can you
> comment on proper construction of duplicated Vecs which are needed by
> Krylov solver of PETSc? The way I am
> doing is :
> a) Create a wrapper Vec (x), which holds SAMRAI vector.
> b) Define a x->ops->duplicatevector for this wrapper vector.
> c) Create a VecNest (X) of these wrapper Vecs.
> d) Define MatGetVecs routine, which will duplicate X by the call
>     VecDuplicate(X,left/right)
This much is fine.
> On Thu, Feb 28, 2013 at 2:27 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
>> This is calling VecValidValues() checks for vec->ops->getarray. Since
>> VecGetArray_Nest() is implemented, it calls the routine. I'm inclined to
>> add a vec->ops->validvalues() and _not_ try to hack it in terms of
>> VecGetArray().
> Amneet
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130301/af72f4c7/attachment.html>
