[petsc-users] no-debug-mode problem
Fri Jun 28 17:25:41 CDT 2013
  Run both debugged and optimized versions with valgrind: http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
   Barry
On Jun 28, 2013, at 3:30 PM, Longxiang Chen <suifengls at gmail.com> wrote:
> A is formed by three arrays IA[NZ], JA[NZ] and VA[NZ]
> IA[i] is row index, JA[i] is column index and VA[i] is the value in (IA[i], JA[i]).
> For intel compiler:
> when I use --with-debugging=0, the VA[] is not correct. I don't know what kind of optimization it does.
> A[0][0] = 1.000000e-25
> A[0][1] = 0.000000e+00
> A[0][2] = 0.000000e+00
> A[1][0] = 0.000000e+00
> A[1][1] = -3.479028e+02
> A[1][2] = 0.000000e+00
> A[2][0] = 0.000000e+00
> A[2][1] = 0.000000e+00
> A[2][2] = -3.479028e+02
> A[3][3] = 1.000000e-25
> CORRECT:
> A[0][0] = -2.961372e-07
> A[0][1] = 1.160201e+02
> A[0][2] = 2.744589e+02
> A[2][0] = -8.332708e-08
> A[3][3] = -3.027917e-07
> For gcc-4.7.2:
> when I use --with-debugging=0, the fortran main function cannot read input data before it starts the LOOP, the ksp_solver() is called inside the loop.
>  ERRONEOUS DATA INITIALIZATION            STOP EXECUTION---------
> Best regards,
> Longxiang Chen
> Do something everyday that gets you closer to being done.
> On Thu, Jun 27, 2013 at 6:42 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> On Jun 27, 2013, at 2:23 PM, Tabrez Ali <stali at geology.wisc.edu> wrote:
> > Fortran can be tricky.
> > Try to run the program in valgrind and/or recheck all your arguments. I once forgot MatAssemblyType in the call to MatAssembly and the code still ran fine on one machine but failed on other. It is better to test with at least 2-3 compilers (GNU, Solaris and Open64 Fortran/C compilers are all free on Linux).
> > T
>    You can also run both versions with -snes_monitor -ksp_monitor and see if they both start out the same way.
>    Barry
> > On 27.06.2013 14:52, Longxiang Chen wrote:
> >> Dear all,
> >> I use ksp_solver to solve Ax=b, where A is from an outer loop of PDE.
> >> Under debug mode(default), it solves the problem in about 4000
> >> iterations.
> >> And the final answer is correct (comparing to another solver).
> >> I use intel compiler.
> >> The program is in Fortran (by mpif90), except the solver is in c (by
> >> mpicc).
> >> However, when I re-configure with --with-debugging=0 (the only
> >> change),
> >> the program terminates in about 30 iterations with the wrong final
> >> solution.
> >> Thank you.
> >> Best regards,
> >> Longxiang Chen
