[petsc-users] 1d FFT of 2D vector (using fftw for preference)
Fri Jun 28 09:10:23 CDT 2013
Matthew Knepley <knepley at gmail.com> writes:
> I do not know of one other than repeated calls to the 1D transform. If
> you can find it in the FFTW API when could put it in.
I used this:
  c->p_forward = fftw_plan_guru_r2r(1, &(c->tdim), c->rank-1, c->dim, x, c->work, &redft00, flag | FFTW_PRESERVE_INPUT);
https://github.com/jedbrown/spectral-petsc/blob/master/chebyshev.c#L127
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130628/216785e8/attachment.pgp>
