[petsc-users] Unreproducible number of iterations for	consecutives solves (GCR + ML)
    Mark F. Adams
    mark.adams at columbia.edu
    Thu Jun 27 09:40:05 CDT 2013
If this happens in serial and does not happen with other solvers then there is probably a non-deterministic random seed (RHS for the eigen estimator...).  I could imagine the documentation not going into that much detail, but I would not imagine that ML would be non-determinstic by default ...  It could be a floating point issues also.
On Jun 27, 2013, at 4:08 AM, Thomas DE-SOZA <thomas.de-soza at edf.fr> wrote:
> Dear PETSc users,
> We've been using the Krylov solvers in PETSc for a while in our software package for implicit structural mechanics and recently added algebraic multigrid preconditioning through the ML and Hypre libraries provided as part of PETSc.
> Though we're quite happy with this new feature, we've encountered a strange behaviour when using KSPGCR in conjunction with the PCML preconditioner.
> Indeed, identical and  consecutives solves inside the same run do not display the same number of Krylov iterations even in sequential and we were wondering why :
> 1st solve
> 723 KSP unpreconditioned resid norm 2.911385065051e-02 true resid norm 2.911385065051e-02 ||r(i)||/||b|| 9.979426047969e-09
> 2nd solve
> 787 KSP unpreconditioned resid norm 2.896035212670e-02 true resid norm 2.896035212670e-02 ||r(i)||/||b|| 9.926810982197e-09
> 3rd solve
> 721 KSP unpreconditioned resid norm 2.913123687343e-02 true resid norm 2.913123687343e-02 ||r(i)||/||b|| 9.985385566274e-09
> Would you say this case requires a great number of iterations and therefore reproductibility is not ensured (indeed it is ill-conditioned and is not very suited for algebraic multigrid) ?
> Or is there a seed somewhere in ML that would explain this ? I searched the ML manual for that and couln't find any. We're using the uncoupled coarsening scheme in ML (call PetscOptionsSetValue('-pc_ml_CoarsenScheme', 'Uncoupled', ierr)).
> Final notes : several consecutive runs of the program do display identical behaviour (that is the 1st solve always require 723 iterations, the 2nd 787, etc). Moreover other cases that are well-conditioned require the same number number of iterations for each consecutive solve (though the converged residual differs a bit).
> Thanks for any hints,
> Thomas
> Ce message et toutes les pièces jointes (ci-après le 'Message') sont établis à l'intention exclusive des destinataires et les informations qui y figurent sont strictement confidentielles. Toute utilisation de ce Message non conforme à sa destination, toute diffusion ou toute publication totale ou partielle, est interdite sauf autorisation expresse.
> Si vous n'êtes pas le destinataire de ce Message, il vous est interdit de le copier, de le faire suivre, de le divulguer ou d'en utiliser tout ou partie. Si vous avez reçu ce Message par erreur, merci de le supprimer de votre système, ainsi que toutes ses copies, et de n'en garder aucune trace sur quelque support que ce soit. Nous vous remercions également d'en avertir immédiatement l'expéditeur par retour du message.
> Il est impossible de garantir que les communications par messagerie électronique arrivent en temps utile, sont sécurisées ou dénuées de toute erreur ou virus.
> ____________________________________________________
> This message and any attachments (the 'Message') are intended solely for the addressees. The information contained in this Message is confidential. Any use of information contained in this Message not in accord with its purpose, any dissemination or disclosure, either whole or partial, is prohibited except formal approval.
> If you are not the addressee, you may not copy, forward, disclose or use any part of it. If you have received this message in error, please delete it and all copies from your system and notify the sender immediately by return message.
> E-mail communication cannot be guaranteed to be timely secure, error or virus-free.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130627/a2ca4d5e/attachment.html>
