[petsc-users] Réf. : Re: Unreproducible number of iterations for consecutives solves (GCR + ML)
Thomas DE-SOZA thomas.de-soza at edf.fr
Thu Jun 27 04:38:05 CDT 2013
Hi Dave,
Strangely, it only occurs when we use ML. Other preconditioners we have
tested so far include BoomerAMG from Hypre and a homemade preconditioner
based on a single precision factorization with MUMPS. Both are OK.
Thomas
dave.mayhem23 at gmail.com
27/06/2013 11:21
        Pour :  thomas.de-soza at edf.fr
        cc :    petsc-users at mcs.anl.gov
        Objet : Re: [petsc-users] Unreproducible number of iterations for
Hi Thomas,
Does this behaviour only occur when using ml, or do you see this with
other preconditioners as well?
On Thursday, 27 June 2013, Thomas DE-SOZA wrote:
Dear PETSc users,
We've been using the Krylov solvers in PETSc for a while in our software
package for implicit structural mechanics and recently added algebraic
multigrid preconditioning through the ML and Hypre libraries provided as
part of PETSc.
Though we're quite happy with this new feature, we've encountered a
strange behaviour when using KSPGCR in conjunction with the PCML
preconditioner.
Indeed, identical and  consecutives solves inside the same run do not
display the same number of Krylov iterations even in sequential and we
were wondering why :
1st solve
723 KSP unpreconditioned resid norm 2.911385065051e-02 true resid norm
2.911385065051e-02 ||r(i)||/||b|| 9.979426047969e-09
2nd solve
787 KSP unpreconditioned resid norm 2.896035212670e-02 true resid norm
2.896035212670e-02 ||r(i)||/||b|| 9.926810982197e-09
3rd solve
721 KSP unpreconditioned resid norm 2.913123687343e-02 true resid norm
2.913123687343e-02 ||r(i)||/||b|| 9.985385566274e-09
Would you say this case requires a great number of iterations and
therefore reproductibility is not ensured (indeed it is ill-conditioned
and is not very suited for algebraic multigrid) ?
Or is there a seed somewhere in ML that would explain this ? I searched
the ML manual for that and couln't find any. We're using the uncoupled
coarsening scheme in ML (call PetscOptionsSetValue('-pc_ml_CoarsenScheme',
'Uncoupled', ierr)).
Final notes : several consecutive runs of the program do display identical
behaviour (that is the 1st solve always require 723 iterations, the 2nd
787, etc). Moreover other cases that are well-conditioned require the same
number number of iterations for each consecutive solve (though the
converged residual differs a bit).
Thanks for any hints,
Thomas
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130627/2bb8ad83/attachment.html>
Ce message et toutes les pi?ces jointes (ci-apr?s le 'Message') sont ?tablis ? l'intention exclusive des destinataires et les informations qui y figurent sont strictement confidentielles. Toute utilisation de ce Message non conforme ? sa destination, toute diffusion ou toute publication totale ou partielle, est interdite sauf autorisation expresse.
Si vous n'?tes pas le destinataire de ce Message, il vous est interdit de le copier, de le faire suivre, de le divulguer ou d'en utiliser tout ou partie. Si vous avez re?u ce Message par erreur, merci de le supprimer de votre syst?me, ainsi que toutes ses copies, et de n'en garder aucune trace sur quelque support que ce soit. Nous vous remercions ?galement d'en avertir imm?diatement l'exp?diteur par retour du message.
Il est impossible de garantir que les communications par messagerie ?lectronique arrivent en temps utile, sont s?curis?es ou d?nu?es de toute erreur ou virus.
____________________________________________________
This message and any attachments (the 'Message') are intended solely for the addressees. The information contained in this Message is confidential. Any use of information contained in this Message not in accord with its purpose, any dissemination or disclosure, either whole or partial, is prohibited except formal approval.
If you are not the addressee, you may not copy, forward, disclose or use any part of it. If you have received this message in error, please delete it and all copies from your system and notify the sender immediately by return message.
E-mail communication cannot be guaranteed to be timely secure, error or virus-free.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130627/2bb8ad83/attachment-0001.html>
