[petsc-users] Segmentation fault in PetscInitialize()
Longxiang Chen suifengls at gmail.com
Tue Jun 25 17:54:09 CDT 2013
Dear all,
I try to use ksp to solve Ax=b.
ALL programs are in fortran, except petscsolve() in c.
Because petscsolve() is a sub-function that I don't have argc and argv.
So I use following statement to set the options.
        PetscInitialize(NULL, NULL, NULL, help);
 PetscOptionsSetValue("-ksp_type", "bcgs");
 PetscOptionsSetValue("-pc_type", "jacobi");
PetscOptionsSetValue("-ksp_max_it", "100");
 PetscOptionsInsert(NULL, NULL, NULL);
The program works like this:
main()
Init()
LOOP:
call MULTI (calculate Jacob A)
-> call petscsolve( solve Ax=b)
-> check solution
Goto LOOP
The first iteration works well that I can calculate the solution x from
petscsolve().
But when it enters the second iteration of LOOP, it has Segmentation fault:
Program received signal SIGSEGV, Segmentation fault.
0x000000000d8e11f0 in ?? ()
(gdb) bt
#0  0x000000000d8e11f0 in ?? ()
#1  0x0000000001a32625 in PMPI_Barrier ()
#2  0x0000000000bdd2b7 in PetscLogBegin_Private () at
/home/lchen/ft-petsc/src/sys/logging/plog.c:234
#3  0x0000000000bdd876 in PetscLogBegin () at
/home/lchen/ft-petsc/src/sys/logging/plog.c:278
#4  0x00000000004c1f6c in PetscOptionsCheckInitial_Private ()
    at /home/lchen/ft-petsc/src/sys/objects/init.c:494
*#5  0x00000000004cbe6d in PetscInitialize (argc=0x0, args=0x0, file=0x0, *
*    help=0x20a9f00 "Replace with PETSC_solve") at
/home/lchen/ft-petsc/src/sys/objects/pinit.c:779*
#6  0x00000000004991e3 in petscsolve_ (N=0x20c7d28, RHS=0x9813500,
WKAREA=0x4902c80, NZ=0xc0629e0,
    IA=0xb8b9ac0, JA=0x754e520, CO=0x9871ac0, TOL=0x22c0528,
ITMAX=0x71ef048, ITER=0x7fffffffd3a8,
    ERR=0x7fffffffd3b0, IERR=0x7fffffffd3b8, IUNIT=0x1bcb310,
RWORK=0x57d2000, LENW=0x49f4cc0,
    IWORK=0x3e32860, LENIW=0x49f4cc8) at petscsolve.c:184
#7  0x000000000044ed15 in lineq () at t2cg22.f:1698
#8  0x000000000046a24c in cycit () at t2f.f:2055
#9  0x00000000004483d3 in tough2 () at t2cg22.f:625
#10 0x000000000040bfcc in main ()
Are there any problems with PetscInitialize(NULL, NULL, NULL, help)?
Thank you.
Best regards,
Longxiang Chen
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130625/7ccddf99/attachment.html>
