[petsc-users] How to understand these error messages
Fande Kong fd.kong at siat.ac.cn
Fri Jun 21 02:05:08 CDT 2013
The code works well with less cores. And It also works well with
petsc-3.3-p7. But it does not work with petsc-3.4.1. Thus, If you can check
the differences between petsc-3.3-p7 and petsc-3.4.1, you can figure out
the reason.
On Fri, Jun 21, 2013 at 2:39 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> Fande Kong <fd.kong at siat.ac.cn> writes:
> > These messages come from MatStashScatterGetMesg_Private() line 632 in
> > /src/mat/utilsmatstash.c. I do not send values. I just try to
> > use MatAssemblyEnd/begin() to assembly stiffness matrix.
> It is most likely memory corruption caused by something earlier.  Is it
> reproducible?  (It looks like you're running at fairly large scale.)  I
> wonder if something earlier misuses 32- versus 64-bit ints.
Fande Kong
ShenZhen Institutes of Advanced Technology
Chinese Academy of Sciences
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130621/b0fbeb47/attachment.html>
