[petsc-users] RE : How to get bandwidth peak out of PETSc log ?
Fri Jun 21 01:56:28 CDT 2013
On Fri, Jun 21, 2013 at 8:45 AM, HOUSSEN Franck <Franck.Houssen at cea.fr>wrote:
> Hello,
> The log I attached was a very small test case (1 iteration) : I just
> wanted to get some information about PETSc log printings (time, flops...).
> I profiled the code over "big" test case with scalasca : I know I spend 95%
> of the time calling PETSc (on realistic test cases).
> Barry,
> I have attached 2 logs over 1 and 2 procs running a intermediate test case
> (not small but not big).
> From PETSc_1proc.log, I get :
> Summary of Stages:   ----- Time ------  ----- Flops -----  --- Messages
> ---  -- Message Lengths --  -- Reductions --
>                         Avg     %Total     Avg     %Total   counts
> %Total     Avg         %Total   counts   %Total
>  0:      Main Stage: 2.6379e+02 100.0%  9.8232e+10 100.0%  0.000e+00
> 0.0%  0.000e+00        0.0%  2.943e+03 100.0%
> My understanding is that the relevant figure is 9.8232e+10 (flop) /
> 2.6379e+02 (sec) = 3.72e12 flops = 3723 gflops for 1 proc.
> From PETSc_2procs.log, I get :
>  0:      Main Stage: 1.6733e+02 100.0%  1.0348e+11 100.0%  3.427e+04
> 100.0%  2.951e+04      100.0%  1.355e+04 100.0%
> My understanding is that the relevant figure is 1.0348e+11 (flop) /
> 1.6733e+02 (sec) = 6.18e12 flops = 6184 gflops for 2 procs.
> Am I correct ?
> My understanding is that if the code scales "well", when I double the
> number of MPI processes, I should double the flops which is not the case (I
> get 6184 gflops instead of 2*3723) : right ? wrong ?
> From this, how can I know if I am at the bandwidth peak ?
> If I compare 6184 gflops to the (computer characteristic computed by Matt
> = 12.9 GB/s * 1 flops/12 bytes =) 1.1 GF/s, I get a huge difference that I
> am not sure to understand... I am not sure I can compare these numbers : I
> guess no ?! Did I miss something ?
The bandwidth limit depends on the operation. Some operations, like DGEMM
have no limit, whereas others like VecAXPY do. That is
why it is meaningless to just report flop numbers.
> More over I realize that I get :
> Event                Count      Time (sec)     Flops
>       --- Global ---  --- Stage ---   Total
>                    Max Ratio  Max     Ratio   Max  Ratio  Mess   Avg len
> Reduct  %T %f %M %L %R  %T %f %M %L %R Mflop/s
> VecAXPY            14402 1.0 5.4951e+00 1.0 6.63e+09 1.0 0.0e+00 0.0e+00
> 0.0e+00  2  7  0  0  0   2  7  0  0  0  1206 (in PETSc_1proc.log => 1.2
> gflops which is superior to the 1.1 gflops computed by Matt)
> VecAXPY            14402 1.0 4.3619e+00 1.0 3.32e+09 1.0 0.0e+00 0.0e+00
> 0.0e+00  3  6  0  0  0   3  6  0  0  0  1520 (in PETSc_2procs.log => 1.5
> My understanding is that I can conclude I  am at the bandwidth peak if I
> rely on :
> But I can not conclude anything when I rely on 3723 gflops for 1 proc /
> Can somebody help me to see clear on that ?!
What the above shows is that you get very little improvement from the extra
process, so your machine does not have enough bandwidth to support
those two 2 processors for this operation. Thus I would not expect to see
speedup from 1 to 2 processors on this machine.
    Matt
> Thanks,
> FH
> De : Barry Smith [bsmith at mcs.anl.gov]
> Date d'envoi : jeudi 20 juin 2013 23:20
> À : HOUSSEN Franck
> Cc: petsc-users at mcs.anl.gov
> Objet : Re: [petsc-users] How to get bandwidth peak out of PETSc log ?
>    Please send also the -log_summary for 1 process.
>    Note that in the run you provided the time spent in PETSc is about 25
> percent of the total run. So how the "other" portion of the code scales
> will make a large difference for speedup, hence we need to see with a
> different number of processes.
>    Barry
> On Jun 20, 2013, at 3:24 PM, HOUSSEN Franck <Franck.Houssen at cea.fr> wrote:
> > Hello,
> > I am new to PETSc.
> > I have written a (MPI) PETSc code to solve an AX=B system : how to know
> the bandwidth peak for a given run ? The code does not scale as I would
> expect (doubling the number of MPI processes does not half the elapsed
> time) : I would like to understand if this behavior is related to a bad MPI
> parallelization (that I may be able to improve), or, to the fact that the
> bandwidth limit as been reached (and in this case, my understanding is that
> I can not do anything to improve neither the performance, nor the scaling).
> I would like to know what's going on and why !
> > Concerning the computer, I have tried to estimate the bandwidth peak
> with the "stream benchmark" : www.streambench.org/index.html. I get this :
> > ~>./stream_c.exe
> > Function    Best Rate MB/s  Avg time     Min time     Max time
> > Copy:           11473.8     0.014110     0.013945     0.015064
> > Scale:          11421.2     0.014070     0.014009     0.014096
> > Add:            12974.4     0.018537     0.018498     0.018590
> > Triad:          12964.6     0.018683     0.018512     0.019277
> > As a conclusion, my understanding is that the bandwidth peak of my
> computer is about 12 200 MB / s (= average between 11 400 and 12 900) which
> is about 12200 / 1024 = 11.9 GB/s.
> > Concerning PETSc, I tried to find (without success) a figure to compare
> to 11.9 GB/s. First, I tried to run "make streams" but it doesn't compile
> (I run petsc3.4.1. on Ubuntu 12.04). Then, I looked into the PETSc log
> (using -log_summary and -ksp_view) but I was not able to find out an
> estimate of the bandwidth out of it (I get information about time and flops
> but not about the amount of data transfered between MPI processes in MB).
> How can I get bandwidth peak out of PETSc log ? Is there a specific option
> for that or is this not possible ?
> > I have attached the PETSc log (MPI run over 2 processes).
> > Thanks,
> > FH
> > <PETSc.log>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130621/fe3a30a0/attachment.html>
