[petsc-users] [EXTERNAL] Re: Using MAGMA subroutines instead of LAPACK in SLEPc
Teranishi, Keita knteran at sandia.gov
Thu Jun 20 15:49:34 CDT 2013
As far as I know, Magma's API us not exactly the same as the original LAPACK.  You may need to hack either Magma's Fortran API or internal SLEPC/PETSc source.
Keita Teranishi
R&D Principal Staff Member
Sandia National Laboratories
Livermore, CA 94551
From: Matthew Knepley <knepley at gmail.com<mailto:knepley at gmail.com>>
Date: Thursday, June 20, 2013 1:42 PM
To: Harshad Sahasrabudhe <hsahasra at purdue.edu<mailto:hsahasra at purdue.edu>>
Cc: "petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>" <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>>
Subject: [EXTERNAL] Re: [petsc-users] Using MAGMA subroutines instead of LAPACK in SLEPc
On Thu, Jun 20, 2013 at 10:24 PM, Harshad Sahasrabudhe <hsahasra at purdue.edu<mailto:hsahasra at purdue.edu>> wrote:
I'm trying to run the SLEPc Eigensolver on a machine with CPUs & GPUs. I found that a package called MAGMA implements LAPACK functions on heterogeneous systems (CPU + GPU). MAGMA has functions very similar to LAPACK so that we can go and replace a call to a LAPACK function with a call to a MAGMA function.
Now my question is, where can I apply such a hack inside SLEPc/PETSc so that the Eigensolver in SLEPc actually uses MAGMA functions instead of LAPACK functions? I'm using the PETSc 3.3-p6 and SLEPc 3.3-p3 versions.
Any help would be greatly appreciated!
You need to do this in PETSc configure. Use --with-f-blas-lapack-lib=[<MAGMA libs>]. We have never tried this, so I don't
know if they obey the entire interface.
  Thanks
Thanks and Regards,
Harshad
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130620/5ad58223/attachment.html>
