[petsc-users] PETSC_VERSION_LT not giving expected result
Jim Fonseca jefonseca at gmail.com
Sun Jun 16 16:20:40 CDT 2013
Of course. I clicked the wrong button. Thanks for the tips.
Jim
On Sun, Jun 16, 2013 at 3:15 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> Please always use "reply-all" so that your messages go to the list.
> This is standard mailing list etiquette.  It is important to preserve
> threading for people who find this discussion later and so that we do
> not waste our time re-answering the same questions that have already
> been answered in private side-conversations.  You'll likely get an
> answer faster that way too.
> Jim Fonseca <jefonseca at gmail.com> writes:
> > Hi Jed,
> > Thanks. Well, I was just going to paste the new directive functions into
> > the petscversion.h we have for our current PETSc 3.2 builds.
> Okay, thanks for explaining.  This is now fixed in 'maint' and 'master'.
> > Yes, I know you probably cringe when you read we are still using
> > that. :) I wanted to use PETSC_VERSION_GE moving forward since that
> > seemed a lot nicer than comparing the version numbers one by one (i.e
> > 3.2, 3.3, 3.4, petsc-dev) I want to try the make the transition from
> > 3.2 to 3.4 as smooth as possible since we run on a few systems and it
> > will be difficult to update all our builds simultaneously (some are
> > cluster modules, some use our own PETSc builds) and test them.
> Yup, understood.  Depending on how your code includes PETSc headers, you
> can do something like this:
> #include <petscsnes.h> /* or whatever */
> #if !defined(PETSC_VERSION_LT)
> #define PETSC_VERSION_LT(MAJOR,MINOR,SUBMINOR)          \
>   (PETSC_VERSION_RELEASE == 1 &&                        \
>    (PETSC_VERSION_MAJOR < (MAJOR) ||                    \
>     (PETSC_VERSION_MAJOR == (MAJOR) &&                  \
>      (PETSC_VERSION_MINOR < (MINOR) ||                  \
>       (PETSC_VERSION_MINOR == (MINOR) &&                \
>        (PETSC_VERSION_SUBMINOR < (SUBMINOR)))))))
> #endif
> ... other stuff for you application
> > Thanks,
> > Jim
> > On Sat, Jun 15, 2013 at 2:51 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> >> Yikes, that should be RELEASE==1. Looks like I totally botched this:
> https://bitbucket.org/petsc/petsc/commits/03354681f90b4c94467f09fd38f90b774d661d87
> >> Will fix when I have a keyboard.
> >> But how can you have this macro with 3.2?
> >> On Jun 15, 2013 7:54 AM, "Jim Fonseca" <jefonseca at gmail.com> wrote:
> >>> Hi,
> >>> In http://www.mcs.anl.gov/petsc/petsc-current/include/petscversion.h
> >>> there is:
> >>>   (PETSC_VERSION_RELEASE == 0 &&                        \
> >>> Won't this always be false for release versions?
> >>> We're trying to move from 3.2 and the following is evaluating to true.
> (I've put the new additions to petscversion.h into that file in our older
> builds).
> >>> #if PETSC_VERSION_GE(3,3,0)
> >>> //we should not get here, but we do
> >>> when petscversion.h has
> >>> #define PETSC_VERSION_RELEASE    1
> >>> #define PETSC_VERSION_MAJOR      3
> >>> #define PETSC_VERSION_MINOR      2
> >>> #define PETSC_VERSION_SUBMINOR   0
> >>> #define PETSC_VERSION_PATCH      6
> >>> Thanks,
> >>> Jim
> >>> Jim Fonseca, PhD
> >>> Research Scientist
> >>> Network for Computational Nanotechnology
> >>> Purdue University
> >>> 765-496-6495
> >>> www.jimfonseca.com
> > Jim Fonseca, PhD
> > Research Scientist
> > Purdue University
> > 765-496-6495
> > www.jimfonseca.com
Jim Fonseca, PhD
Research Scientist
Purdue University
765-496-6495
www.jimfonseca.com
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130616/c25cab5f/attachment.html>
