[petsc-users] configure crash
Dharmendar Reddy dharmareddy84 at gmail.com
Fri Jun 14 13:15:41 CDT 2013
Hello,
         I get the Following error when i use ctetgen: (have a look at the
attached log file, i copied a snippet here). Also, metis and parametis give
error when i configure with scalar-type=complex. I was using MUMPS which
requires either parmetis or pt-scotch. I was able to cinfigure with
ptscotch. At this point, i am just seting up my code, an i do not know
which combination for direct solver will give a good result. I was hoping
to configure with the required packages and then experiment.
         UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for
details):
Cannot use ctetgen with complex numbers it is not coded for this capability
  File "./config/configure.py", line 293, in petsc_configure
    framework.configure(out = sys.stdout)
  File
"/home1/00924/Reddy135/LocalApps/petsc/config/BuildSystem/config/framework.py",
line 933, in configure
    child.configure()
  File
"/home1/00924/Reddy135/LocalApps/petsc/config/BuildSystem/config/package.py",
line 552, in configure
    self.consistencyChecks()
  File "/home1/00924/Reddy135/LocalApps/petsc/config/PETSc/package.py",
line 38, in consistencyChecks
    raise RuntimeError('Cannot use '+self.name+' with complex numbers it is
not coded for this capability')
On Fri, Jun 14, 2013 at 11:29 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> On Thu, 13 Jun 2013, Dharmendar Reddy wrote:
> > Hello,
> >           I rerun the configure, it works. I had to remove the ctetgen,
> > metis and parametis
> I don't unserstand why you had to remove them.
> > Is there documentation on dependencies for external
> > packages ? If not, it will be useful to have a required package list for
> a
> > given external package.
> its currently documented in the appropriate .py file for that package.
> [and if the dependency is missing - you get a configure error]
> Satish
Dharmendar Reddy Palle
Graduate Student
Microelectronics Research center,
University of Texas at Austin,
10100 Burnet Road, Bldg. 160
MER 2.608F, TX 78758-4445
e-mail: dharmareddy84 at gmail.com
Phone: +1-512-350-9082
United States of America.
Homepage: https://webspace.utexas.edu/~dpr342
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130614/6d1d4f16/attachment.html>
