[petsc-users] Error in PETSc with MUMPS on Windows.
Fri Jun 14 12:00:25 CDT 2013
> [0]PETSC ERROR: [0] MatLUFactorSymbolic_AIJMUMPS line 880 src/mat/impls/aij/mpi/mumps/C:\PETSC-~1.1\src\mat\impls\aij\mpi\mumps\mumps.c
So its crashing somewhere in MatLUFactorSymbolic_AIJMUMPS() - which
has calls to mumps routines.
> --with-mpi-dir=/cygdrive/d/Solvers-dev/Solvers/libs/MPI /cygdrive/d/Solvers-dev/Solvers/libs/MPI/lib/fmpich2.lib
Looks like you are using mpich2 - but not standard install?
And Its not clear how one would use blacs/scalapack from mkl. Is it
supporsed to be compatible with this version of mpich you have? [I
have no idea]
Such mixing of mpi compiled codes [where packages are compiled with
different variants of mpi - but combined into a single binary] can
potentially have issues.
And you can do debugging on windows. For sequential you do:
msdev binary.exe
[or whatever the current name for the developer studio is.Its 'devenv' for VC2008, and something elese for VC2012]
And if you wish to debug parallely - you would have to compile the
application with the developer studio project files - and perhaps
follow instructions from:
http://www.mpich.org/static/downloads/1.4.1p1/mpich2-1.4.1p1-windevguide.pdf
Satish
On Fri, 14 Jun 2013, Santos Teixeira  Frederico wrote:
> Hi,
> I got the error below when I tried to execute PETSc with MUMPS. Some important facts:
> 1) the following libraries/versions were compiled separatedly: METIS: 5.1.0, ParMETIS: 4.0.3, MUMPS: 4.10.0 and added to PETSc 3.4.1 along with ScaLAPACK 2.0.2 (plus BLAS, LAPACK, BLACS etc. - from latest MKL).
> 2) the same code works correctly on Windows with Pardiso (interfaced with PETSc).
> 3) the same code works correctly on Linux with Pardiso and the libraries provided by --download-***.
> 4) the MUMPS libraries and its dependencies (the same described below) were linked and correctly executed a test provided by the own library.
> Despite the lack of informations and debugger (Windows...), could you give some tip and/or guide me to provide you better informations? I appreciate any tip!
> Thanks a lot!
> Regards,
>  Frederico.
> Starting KSPSolve with MUMPS...
> Entering DMUMPS driver with JOB, N, NZ =   1       74355        2782474
>  DMUMPS 4.10.0
> L U Solver for unsymmetric matrices
> Type of parallelism: Working host
>  ****** ANALYSIS STEP ********
>  Resetting candidate strategy to 0 because NSLAVES=1
>  ... Structural symmetry (in percent)=   93
>  Density: NBdense, Average, Median   =    0   39   29
>  ... No column permutation
>  Ordering based on METIS
> [0]PETSC ERROR: ------------------------------------------------------------------------
> [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation, probably memory access out of range
> [0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> [0]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind[0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
> [0]PETSC ERROR: likely location of problem given in stack below
> [0]PETSC ERROR: ---------------------  Stack Frames ------------------------------------
> [0]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
> [0]PETSC ERROR:       INSTEAD the line number of the start of the function
> [0]PETSC ERROR:       is given.
> [0]PETSC ERROR: [0] MatLUFactorSymbolic line 2820 src/mat/interface/C:\PETSC-~1.1\src\mat\INTERF~1\matrix.c
> [0]PETSC ERROR: [0] PCSetUp_LU line 99 src/ksp/pc/impls/factor/lu/C:\PETSC-~1.1\src\ksp\pc\impls\factor\lu\lu.c
> [0]PETSC ERROR: [0] PCSetUp line 868 src/ksp/pc/interface/C:\PETSC-~1.1\src\ksp\pc\INTERF~1\precon.c
> [0]PETSC ERROR: [0] KSPSetUp line 192 src/ksp/ksp/interface/C:\PETSC-~1.1\src\ksp\ksp\INTERF~1\itfunc.c
> [0]PETSC ERROR: [0] KSPSolve line 356 src/ksp/ksp/interface/C:\PETSC-~1.1\src\ksp\ksp\INTERF~1\itfunc.c
> [0]PETSC ERROR: [0] FluidSolverDirect::Solve line 1145 "unknowndirectory/"..\..\..\Source\FluidSolver\FluidSolverDirect\FluidSolverDirect.cpp
> [0]PETSC ERROR: --------------------- Error Message ------------------------------------
> [0]PETSC ERROR: Signal received!
> [0]PETSC ERROR: Petsc Release Version 3.4.1, Jun, 10, 2013
> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
> [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> [0]PETSC ERROR: See docs/index.html for manual pages.
> [0]PETSC ERROR: D:\Solvers-dev\Solvers\builds\bin\Debug\FluidSolverDirectCavityDriver.exe on a win-x64-msvc-mkl-real-release named FREDERICO-PC by Frederico Teixeira Fri Jun 14 17:53:16 2013
> [0]PETSC ERROR: Libraries linked from /cygdrive/c/petsc-3.4.1/win-x64-msvc-mkl-real-release/lib
> [0]PETSC ERROR: Configure run at Fri Jun 14 15:34:42 2013
> [0]PETSC ERROR: Configure options PETSC_ARCH=win-x64-msvc-mkl-real-dbg --with-cc="win32fe cl" --with-cxx="win32fe cl" --with-fc=0 --with-x=0 --with-debugging=1 --with-mpi-dir=/cygdrive/d/Solvers-dev/Solvers/libs/MPI --with-blas-lapack-lib="[/cygdrive/d/Solvers-dev/Solvers/libs/MKL/x64/lib/mkl_bl
> as95_lp64.lib,/cygdrive/d/Solvers-dev/Solvers/libs/MKL/x64/lib/mkl_lapack95_lp64.lib,/cygdrive/d/Solvers-dev/Solvers/libs/MKL/x64/lib/mkl_intel_lp64.lib,/cygdrive/d/Solvers-dev/Solvers/libs/MKL/x64/lib/mkl_intel_thread.lib,/cygdrive/d/Solvers-dev/Solvers/libs/MKL/x64/lib/mkl_core.lib]" --with-metis-
> lib=/cygdrive/d/Solvers-dev/Solvers/libs/METIS/win-x64-msvc/lib/metis.lib --with-metis-include=/cygdrive/d/Solvers-dev/Solvers/libs/METIS/include --with-parmetis-lib=/cygdrive/d/Solvers-dev/Solvers/libs/PARMETIS/win-x64-msvc/lib/parmetis.lib --with-parmetis-include=/cygdrive/d/Solvers-dev/Solvers/li
> bs/PARMETIS/include --with-scalapack-lib="[/cygdrive/d/Solvers-dev/Solvers/libs/MKL/x64/lib/mkl_scalapack_lp64.lib,/cygdrive/d/Solvers-dev/Solvers/libs/MKL/x64/lib/mkl_blacs_mpich2_lp64.lib]" --with-scalapack-include=/cygdrive/d/Solvers-dev/Solvers/libs/MKL/include --with-mumps-lib="[/cygdrive/d/Sol
> vers-dev/Solvers/libs/MUMPS/win-x64-msvc-mkl/lib/dmumps.lib,/cygdrive/d/Solvers-dev/Solvers/libs/MUMPS/win-x64-msvc-mkl/lib/mumps-common.lib,/cygdrive/d/Solvers-dev/Solvers/libs/MUMPS/win-x64-msvc-mkl/lib/pord.lib,/cygdrive/d/Solvers-dev/Solvers/libs/MUMPS/win-x64-msvc-mkl/lib/dmumps-f.lib]" --with-
> mumps-include=/cygdrive/d/Solvers-dev/Solvers/libs/MUMPS/include2 --with-hypre-dir=/cygdrive/d/Solvers-dev/Solvers/libs/HYPRE -CFLAGS=-MD -CXXFLAGS=-MD --LIBS="/cygdrive/d/Solvers-dev/Solvers/libs/IntelCompiler/x64/lib/ifconsol.lib /cygdrive/d/Solvers-dev/Solvers/libs/IntelCompiler/x64/lib/libifcore
> md.lib /cygdrive/d/Solvers-dev/Solvers/libs/IntelCompiler/x64/lib/libifportmd.lib /cygdrive/d/Solvers-dev/Solvers/libs/IntelCompiler/x64/lib/libiomp5md.lib /cygdrive/d/Solvers-dev/Solvers/libs/IntelCompiler/x64/lib/libirc.lib /cygdrive/d/Solvers-dev/Solvers/libs/IntelCompiler/x64/lib/libmmd.lib /cyg
> drive/d/Solvers-dev/Solvers/libs/IntelCompiler/x64/lib/svml_dispmd.lib /cygdrive/d/Solvers-dev/Solvers/libs/MPI/lib/fmpich2.lib" --useThreads=0
> [0]PETSC ERROR: User provided function() line 0 in unknown directory unknown file
> application called MPI_Abort(MPI_COMM_WORLD, 59) - process 0
> job aborted:
> rank: node: exit code[: error message]
> 0: Frederico-PC: 59: process 0 exited without calling finalize
